Auto rollup window function not working
Old Jul 2, 2009 | 07:25 PM
lefizzet's Avatar
So I just picked up my car this afternoon from the body shop after getting rear ended at a stoplight =/. Driving wise everything is fine, but then I noticed that the right rear window auto roll up function doesn't work, but the auto roll down function still does. The impact was mainly to the right rear side, so could that have any correlation? Any help is appreciated, thanks.
*Note* also, the trick you can do by manually inserting your key into the keyhole and then holding it to the lock position closes all the windows, coincidentally the right rear window doesn't close when I do this
Here's a pic from the trunk
http://i49.photobucket.com/albums/f2...5/DSC00900.jpg
http://i49.photobucket.com/albums/f2...5/DSC00888.jpg
Old Jul 2, 2009 | 09:48 PM
E-Ticket Ride's Avatar
Since the body shop probably disconnected your battery, you just need to reset the windows via the switches.
Old Jul 2, 2009 | 11:45 PM
lefizzet's Avatar
Can you please elaborate? What exactly do you mean by switches, thanks.
Old Jul 3, 2009 | 12:05 AM
CalsonicVQ's Avatar
OP, check the FAQs.
Old Jul 3, 2009 | 12:09 AM
tg1234's Avatar
Nevver had to do it but I believe you roll down your windows and roll them up and hold the switches few more seconds after they are up. I think it is in the manual also.
Old Jul 3, 2009 | 12:18 AM
lefizzet's Avatar
Got it, thanks!
mike730
Jan 12, 2018 04:25 PM
joedaddy1
Jul 28, 2015 02:58 PM
apintojr
Jul 23, 2015 10:52 AM
mjfenix
Jul 17, 2015 02:07 PM
