installed a subwoofer nd it didnt work.
Old Aug 2, 2009 | 01:34 AM
firozu's Avatar
i put a subwoofer in todai...unfortunatly there are no write ups or anytype of help what so ever to install a system in a non bose system...
so when i installed it it worked but i cant turn my car off...
its soo frustrating...i just ripped it out and left it plus the panels are all not going baq in properly.
any one no what to do?
Old Aug 2, 2009 | 01:56 AM
PhantomCoupe's Avatar
hmm. I did a sub install myself a few weeks back. but i had an aftermarket deck. i installed it all and had no problems. Just with the plastics go very slow in putting them back. if they don't go in easily, take it apart and try again. Don't try to force it. :P
*** Be very careful, if things are getting frustrating. Call it quits for the night. Start fresh in the morning. its better to quit while your ahead and not break somthing out of frustration or lack of concentration.
good luck man. it shouldn't be too hard.
Old Aug 3, 2009 | 12:19 AM
firozu's Avatar
i have the new sedan tho.. i dont think u can install a system atleast not by running a power wire to the battery...sux...
Old Aug 3, 2009 | 10:10 AM
mishmosh's Avatar
Why wouldn't you be able to run the power wire to the battery? What do you mean you could turn the car off? You mean the SUB didn't turn off or the car?
Old Aug 3, 2009 | 04:22 PM
blazeplacid's Avatar
if your car wont turn off you went way off
if your sub stays on when your turn the car off, you have it wired to 12v contstant not switched.
When you wire it to switched it should turn on when you turn the key and turn off when you turn the car off.
How are you tapping into the wires in the G?
Are you using a line out put converter to convert your signal to RCA?
Or are you tapping into the lines and running it to an amp with speaker level inputs?
Old Aug 3, 2009 | 09:01 PM
firozu's Avatar
ok i got it, basically for some reason u have to watch where u connect the power wire. I connected it to a bolt closer to the other wires i guess causing the entire car itself to stay on not just the system.. anyway i connected it to the bolt that u use to tighten the terminal and it worked perfectly...so if anyone needs help or advice please feel free to ask
also it sounds beautiful really clean on the inside tho it does rattle from outside but at this point i could care less about that.
Old Aug 4, 2009 | 08:21 AM
wow man, it sounds like maybe you should of had someone help you out.
Taping into wires that you arent sure of is not good a practice.
you should always wire your amp directly to the battery, where did you have it previously?
Old Aug 5, 2009 | 12:35 AM
firozu's Avatar
i did connect the amp directly to the battery...the bold i used tho appearently u cant use so i used the bolt thats used to tighted the terminal to the battery instead
Old Aug 5, 2009 | 12:45 AM
Xet's Avatar
Xet
what? i dont understand even how you can wire it up and have your car not be able to turn off.... you ran a separate wire like you should. you connected it to the battery terminal. you had a fuse. you had a ground in the back? whaaa???
mike730
Jan 12, 2018 04:25 PM
Hotdawwgman
Sep 18, 2015 04:19 PM
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
Domesticdemon
Northern California
Aug 27, 2015 10:52 PM
Frostbite91
Aug 2, 2015 04:59 PM
