Invisicord = Laser warning
Old Nov 7, 2010 | 01:28 AM
theaudir8fan's Avatar
Question Invisicord = Laser warning
I just installed the invisicord and mount on my 2007 Infiniti G35S my detector is a Passport 9500i. It works, but it keeps singling laser warning randomly! this started to happen right after i installed my invisicord and went out for a drive. after that there has been a few times where it would just sound laser warning continuously right after i start the engine, and when reboot the detector, it will go back to normal. but when driving it would just sound laser alert when there is nothing around and then die off immediately after the signal was detected.
Any ideas as to why this is?
thanks
Old Nov 7, 2010 | 01:19 AM
mathnerd88's Avatar
thanks
If you have the tech package, it may be picking up laser from your laser cruise control...if not, then try it with the normal power cord and see if it works normally. I don't approve using the invisicord because it takes power from the mirror and may cause power issues later in the future. I used the add a fuse kit and hardwired my Escort Redline to my fusebox and works really well. I don't get laser warnings even with the tech package.
I don't have the tech package, so no active curse or navi, I also wasn't using the curse control on the drive, i was in the city for the entire way. the fuse kit is very complicated which is what i kind of hate. the detector is power fine but i just don't understand where the random signal is coming from. I will do more driving on Monday and see if anything changes
Old Nov 7, 2010 | 01:37 AM
That1GuyG35's Avatar
You should first hook it back up like you had it and see if the problem continues. If so, well, you need to get this warrantied out.
Hooking this up to the mirror will not cause a problem. I have had my V1 installed on my mirror in my 06 G coupe and my last 2 STi's with no issues. The V1 is about 4 years old and has spent 6 months in the G like this with no issues. If there was a problem or high current draw it would blow the fuse like its suppose to.
I would look at the unit to see if there is a problem with it first. My old room mate had one of these and it gave him random problems (same laser issue as you described) in the 2 years he owned it.
Old Nov 7, 2010 | 01:16 PM
kool_yaar's Avatar
I had that happen when i mounted my radar on blendmount and pointed it down a bit, i am pretty sure it picks up on the Cd players laser, i straightened it out and have had no issues since!
Old Nov 7, 2010 | 11:03 PM
mishmosh's Avatar
The center console screen set off my Escort the same way! I changed it from a rearview mount to a visor clip mount and the problem was gone.
Old Nov 8, 2010 | 12:06 PM
An update, i realized today that the problem isn't caused by invisicord, it's the mounting location, i tried the original cord and the same issue occurred.
Kool_yarr, can you explain straightening out. what do you mean by it. I try to make the detector as horizontal as possible and the issue still occurs.
mishmosh, what is a visor clip mount, can you send me a link to it?
thanks
Old Nov 8, 2010 | 12:59 PM
speedracerg35's Avatar
I've had an issue just recently start to occur. I have a blendmount and invisicord forboth my g37 and my ford explorer. I have a v1 in the g and an escort 8500 in the explorer. The v1 works perfectly fine, but the escort has been falsing randomly with laser. The weird thing is, it will also go off if I honk the horn. This will happen on the first honk only. If I honk again immediately, the laser does not go off. Ive tried this every other day or so, laser warning on the first press of the horn, then nothing.
Old Nov 9, 2010 | 01:53 AM
i have now figured out that the detector just picks up laser signals when it's placed around the area under the mirror, everywhere else is fine. Does anyone has any ideas as to why this it?
Old Nov 9, 2010 | 08:23 AM
mishmosh's Avatar
I already said the center console screen is likely setting it off. Take the detector off it's mount and start pointing it around. The screen is giving off a false positive on laser.
Old Nov 9, 2010 | 08:27 AM
javisaman's Avatar
I had the same problem with my Escort 9500xi. For me it was the automatic brightness (day/night button) on the nav screen. The laser warning goes off immediately if I turn it on. The detector is mounted on the rearview mirror using stealthcord and blendmount.
JG_G35
Apr 29, 2016 04:46 AM
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
carid
Group Buys-Vendor
Aug 7, 2015 12:17 PM
