HKS Camp 2 Install
Old Dec 17, 2010 | 08:49 AM
Q8y_drifter's Avatar
HKS Camp 2 Install
I've had the Camp 2 for a few months now but haven't had the time to install everything until today. Right now, I'm only using the main unit with no extra sensors. Once i get my GTM SC kit I'll purchase all the extra sensors for oil temp, oil pressure, boost and fuel pressure.
Anyhow, I'm simply gonna be posting pics and some writing, basically on where I mounted the unit and how everything is routed on my setup. It is far from ideal so I might tinker with the layout later on, but for now I'm pretty happy with it.
First things first, I mounted the unit under the glove box using 3M double sided tape and connected the A/V input wires, receiver wire and the OBDII wires.
Then I removed the shift ****
And proceeded to remove the center console
I routed the receiver and OBDII wires across the inside of the console from the passenger foot rest and out the other side to the driver's foot rest area.
All the wires were hidden inside, between the trim and carpet
The OBDII wire was secured with strips of double sided tape and mounted on the inside of the dash under the steering wheel.
The receiver was also secured with double sided tape between the steering wheel and console
The A/V input wires were hidden between the trim and carpet on the passenger side and plug into the factory A/V inputs.
Old Dec 17, 2010 | 11:06 AM
Austin713's Avatar
thats pretty sweet, do you have the nav hack done to prevent that screen from going blank when your moving?
Is your G a eurospec? those center console buttons are funky, looks to be a parking sensor button where the snow/ice button and a bluetooth/handsfree where the seat heaters are.
Old Dec 17, 2010 | 11:10 AM
Ketchup83se01's Avatar
looks good, but now you can't use the obd2 socket right?
Old Dec 17, 2010 | 02:08 PM
Defratos's Avatar
You're Despicable
Austin his car is a GCC Spec (Middle East)
Looking good dude,
I'm going to be ripping out my interior sometime within the next few weeks. This might be the right time to do a similar install.
I'm trying so hard not to spend more monies
Old Dec 17, 2010 | 03:48 PM
Austin, no not yet. I'll be working on that later on.
Ketchup, the OBDII connector can be plugged and unplugged at any time. It's not permanent or anything. I also have the Uprev Osiris cable which I use for data logging and tuning.
Old Dec 17, 2010 | 04:58 PM
terrycs's Avatar
I've actually seen "Y" connectors on the internet somewhere too.
Old Dec 22, 2010 | 05:13 AM
docaam's Avatar
nice man...can you post some more pictures later
Old Dec 22, 2010 | 05:37 AM
Thanks.
pics of what?
Old Dec 22, 2010 | 05:54 AM
Defratos's Avatar
You're Despicable
^ Loooool
I agree I'm not sure what pics he's asking for either
Old Dec 23, 2010 | 04:48 AM
docaam's Avatar
LOL pic of other measures if you can have those on the screen?
gatorglaze
Sep 10, 2015 12:03 PM
Machine Head
Sep 4, 2015 07:22 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
itztwinki3
Steering & Suspension
Aug 18, 2015 03:38 PM
