Stereo Nav HVAC glitch
Old Mar 2, 2011 | 04:01 PM
bsowhat1's Avatar
Has anyone had any electronics glitches? On 2 occasions I have started my car and found the nav system frozen with the clock stuck at the time that I last turned off the car. The stereo and HVAC will be locked up and nonfunctional. Turning the car off and on doesn't fix the problem. The system seems to reboot on it's own after 10 minutes. Yesterday I had a separate glitch where the interior door lock switch didn't work. The outside button worked though. After I operated the outside button then the inside switch started working. None of this gives me faith in all the integrated electronics.
Old Mar 2, 2011 | 05:46 PM
astonv12's Avatar
I had a similar problem. Happened 2 times now. I couldn't change music tracks or turn up/down the vol. But when I turn off the car and then turn it back on, the problem went away. Not sure how I'm gonna show the dealership this problem when it only happens on very rare occasions.
Old Mar 2, 2011 | 06:53 PM
kool_yaar's Avatar
i have seen a few ppl on here who had this problem, finally when they were able to replicate the problem to the dealer i believe they changed out the screen(someone correct me if im wrong) to solve the issue which is a bit weird but it worked out well.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
G35xdriver04
Nov 7, 2015 08:31 PM
mattdg35
Sep 14, 2015 11:28 AM
2014g35x
Sep 11, 2015 07:53 PM
