07 Bose system with aftermarket amp/sub
Old Apr 20, 2011 | 10:18 PM
Asmoa's Avatar
Hi all, I have a 2007 G35S sedan with Bose system and I'd like to add an after market amp/sub combo from my old car. I've been doing alot of reading about this and I just wanted to clarify a couple things.
My amp is a JL 250/1 and it has differential-balanced inputs so all I should have to do is splice a pair of RCA's into the stock system. I'm not really clear on where I should be splicing in tho. I have all the wiring diagrams, just point me in the right direction!
Also should I be using twisted pair RCA's or something different?
Thanks
Old Apr 20, 2011 | 10:22 PM
Hi-TechG35's Avatar
^Just out of curiosity what size and OHM subs are you running? The twisted RCA's are fine. i don't remember which wires to splice into but I know PAC has a unit that you can connect to the radio (some sort of Hi/Low converter) that allows you to set the balance on the amp.
Old Apr 20, 2011 | 11:20 PM
Asmoa's Avatar
I'm using a 10" sub, Dual 4 ohm.
I'm not looking to use a LOC or converter, my amp can take high voltage input from the oem system.
Old Apr 21, 2011 | 04:04 PM
Asmoa's Avatar
bump! From my reading, I'm guessing i should splice the RCA's in before the bose amp. The RCA's that I bought have two wires within each cable, power/ground. I'm guessing that i combine the power from both and the ground from both and slice that into the wiring harnesses +/-. Can anyone confirm this?
jilljann1
Jul 21, 2020 08:12 AM
mattdg35
Sep 14, 2015 11:28 AM
Batfinity
Intake & Exhaust
Sep 9, 2015 09:21 AM
Albanian122
Sep 7, 2015 07:41 PM
