AMP Advice
Old Jun 8, 2011 | 04:18 PM
ABN35's Avatar
AMP Advice
I am new to the G35 world and love my "new" car, a 2008 G35x. I have a older Rockford Fosgate Power HX2 but dont know where my amp ran off too. I had a 1001bd. Anyway, I dont want to spend $400 on another amp. Is there any recommendations? How difficult is it to install a sub through the nav unit?
Old Jun 13, 2011 | 11:05 AM
RemmyZero's Avatar
well if you want to put in a new sub it's not that tough, although to be fair the stock amp won't drive your RF sub as hard as you're probably hoping it will.
there are alot of threads here for installing Line Out Converters and running wires (and plenty on replacing the stock sub with an aftermarket one) so take a look around and let us know if what you find doesn't help you. in reality you'll want a better amp, even a cheap one might do (check craigslist or ebay). i like alpine personally but there are so many good ones out there now. or spend $200 on a bazooka tube if you want to save space.
Old Jun 13, 2011 | 03:20 PM
ABN35's Avatar
I was planning on buying an amp, RF 1051s or R1000-1D. I wasn't sure which direction to go with power output and dont know much about channels, ohms, ect... Im not wiring smart at all so I was planning on taking it to a stereo shop here in birmingham to get it done. Im a finance manager, not a car tech so I was looking for some wisdom.
Old Jun 14, 2011 | 09:11 AM
RemmyZero's Avatar
ah i gotcha. well if you're going with a single sub you just need a mono amp (channels don't so much matter). for ohms it really isn't an option unless you're changing your sub up. you will need to see if your sub voice coil is a 2ohm or 4ohm coil (it's likely 4ohm).
personally, as i said, i like alpine. they have some small mono amps you can grab for cheap on sale at best buy.
Old Jul 5, 2011 | 12:26 PM
Kickeraudio21's Avatar
Cheap Solution:
http://www.sonicelectronix.com/item_...RZ1200.1D.html
Best amplifier for this price. Good quality, expect about 1000 watts rms.
Medium Solution:
http://www.sonicelectronix.com/item_...1DX1000.1.html
Great amp. About 1050 watts rms
Best Solution:
http://www.soundsolutionsaudio.com/s...252d1200D.html
Exceptional quality and sound. You will notice the difference. 1200-1300 watts rms.
Old Jul 8, 2011 | 11:51 AM
ABN35's Avatar
what about kenwood?
http://www.kenwoodusa.com/Car_Entert...iers/KAC-9105D
Old Jul 8, 2011 | 05:53 PM
RemmyZero's Avatar
kenwood makes good stuff too. its really just personal preference or price in the end. i would recommend maybe finding a car audio store where you can listen to different subs though, that may be beneficial for you to make a decision.
Old Jul 8, 2011 | 07:34 PM
That kenwood amp is mediocre quality, and it still costs a lot. You'd be better off with almost any other brand. I used to be a professional installer and I've had almost every brand of amps in my vehicles at on time or another.
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
6spdGspot
Oct 5, 2015 01:55 PM
dcsbh1
Oct 1, 2015 03:15 PM
