2008 G35 w XM& NAV and Iphone options
Old Feb 7, 2012 | 09:57 AM
swabby111's Avatar
Hello
Been scouring the site for option for playing and charging my iphone. Would like to use the USA Spec....Has anyone with a 2008 G35 XM & NAV been able to get it to work?
Or any other options. Called Crutchfield and they have nothing...Got to be something out there..
Thanks
Bob
Old Feb 7, 2012 | 12:16 PM
Mrpeeng's Avatar
If you have an iphone i think 4 and up you can use the following and add it to the iphone attachment built into the car (center arm rest).
http://www.amazon.com/Scosche-passPORT-Charging-Adapter-iPhone/dp/B001HN6CVA/ref=pd_bxgy_e_img_b http://www.amazon.com/Scosche-passPORT-Charging-Adapter-iPhone/dp/B001HN6CVA/ref=pd_bxgy_e_img_b
Old Feb 7, 2012 | 04:01 PM
swabby111's Avatar
Thanks...I've tried that and the longer cable version but I get a loud hum and the Scosche doesn't fall off the iphone
Was looking for a more permanent
Old Feb 7, 2012 | 04:55 PM
xyrcncp's Avatar
http://www.amazon.com/Scosche-passPO...d_bxgy_e_img_b
Actually it even works on the 3G iPhone. I'm using my wife's old iPhone as an iPod only (no service, in airplane mode) and got the Scosche passPORT in the mail today from Amazon, works perfectly.
I'm guessing any humming noise would come from interference with the phone's cell signal.
Old Feb 9, 2012 | 10:24 AM
RemmyZero's Avatar
the humming shouldn't be caused by the cell signal. sounds like the scosche piece may be causing a change in the ground loops, which is typically where interference comes from in stereos.
if you want to play your iphone are you able to just pair it over bluetooth? you could then hardwire a charger to the car. otherwise you may need to look into adding a parrot bluetooth system since it has an iPhone adapter option. i don't think there is much out there for adding iPods to the Nav system.
you may want to consider trying a different dock adapter to see if that eliminates the ground hum, then place the extension cable on top of it, which would eliminate the cable falling out of the iPhone port.
http://www.google.com/products/catalog?q=iPhone+charging+adapter&oe=utf-8&rls=org.mozilla:en-USfficial&client=firefox-a&um=1&ie=UTF-8&tbm=shop&cid=4549982014414702421&sa=X&ei=uuQzT4S ROIn4sQKt-KWOAg&ved=0CFQQ8wIwAQ
http://www.google.com/products/catalog?q=iPhone+charging+adapter&oe=utf-8&rls=org.mozilla:en-USfficial&client=firefox-a&um=1&ie=UTF-8&tbm=shop&cid=5164727351891860561&sa=X&ei=uuQzT4S ROIn4sQKt-KWOAg&ved=0CFEQ8wIwAA
http://www.cablejive.com/products/dockStubz.html
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
crazy_g35s
Jul 20, 2015 02:30 PM
newbdriver01
Jul 15, 2015 06:10 PM
