Naviks Install..
Naviks Install..
I have a 2007 g35s sedan and Im trying to install my kivic one and Naviks. Can anybody walk me through my Naviks install? Im trying to figure which wires to tap into. Naviks instructions say I need to tap into the 12v purple wire(20 pin plug, pin 7....Also need to figure which 12v trigger wire they are talking bout as well. Says 32 pin plug, pin 30. I need a visual....
This should be nearly identical to the PAC VCI-NIS module installation. If you check out my old thread I may have posted some photos but long story short pull the FSM (as discussed) and all the wires are right behind the head unit and easy enough to get to. It won't take long to get it up and running.
they will downgrade video quality to 1960 composite video signal and possibly limit mirroring capabilities, instead you can get our all in one solution
our products have built in HDMI for mirroring and its the only made in USA 100% automotive grade product
2007-2009 Infiniti G37 Plug & Play Video Interface with HDMI for smartphone mirroring.
Part#NavRGB3.0-HDMI+NI24
Features:
- Limitless HDMI Input for smartphone mirroring, use your favorite navigation apps, Waze app, netflix, youtube, iOS video all works no limit.
- 3.5mm Audio Output.
- 2 Composite Video Inputs.
- Camera Automatically In Reverse.
- Connect factory DVD to display on front navigation Screen.
- USB Charger for smartphone.
- USB Updatable.
- Made In USA.
- 100% Automotive Grade.
- Plug and Play
lavtxa
Sep 21, 2015 11:51 AM
