My morning at Eibach .
Old May 23, 2007 | 11:02 PM
  #151
terrycs's Avatar
Had my car on a lift today:
Picture of camber arm installed:
Picture of toe bolt installed:
Old May 24, 2007 | 01:05 AM
  #152
SinCityG35's Avatar
thanks for the pics.
Old May 24, 2007 | 01:42 AM
  #153
SinCityG35's Avatar
I don't imagine you had to elongate the hole, did you?
Old May 24, 2007 | 02:34 AM
  #154
terrycs's Avatar
Yes, the toe bolt holes were elongated.
Old May 26, 2007 | 03:44 PM
  #155
SinCityG35's Avatar
so is that alignment kit available on market yet? Is it eibach branded, if not what is the brand?
Old May 26, 2007 | 03:48 PM
  #156
dvsmeth0dz's Avatar
looks good!
  #157
SinCityG35's Avatar
Any update on the front Camber arm? Do you have that yet, if not when will they be coming out with it?
Old May 26, 2007 | 11:02 PM
  #158
terrycs's Avatar
I was told they will begin shipping on 6/1. The Eibach alignment kit is made by SPC. You can even see the SPC logo in the first photo in post 151.
Old May 27, 2007 | 12:40 AM
  #159
SinCityG35's Avatar
What are your alignment specs after the install?
Old May 27, 2007 | 01:17 AM
  #160
terrycs's Avatar
Camber is out 1/2 degree in front and everything is perfect at nominal in back. The actual figures are in this thread somewhere.
I don't think I really need the A-arms, but if Eibach wants to test fit them on my car, I'm going!
Old May 27, 2007 | 02:24 AM
  #161
SinCityG35's Avatar
I didn't know that those numbers you posted were with the afmarket camber arms and toe bolts
Old May 27, 2007 | 02:35 AM
  #162
terrycs's Avatar
Sorry for the confusion, I actually posted specs before AND after rear camber arms and toe bolts. The front does not have an alignment kit.
Old May 27, 2007 | 03:02 AM
  #163
SinCityG35's Avatar
I am assuming that is because one is not out yet?
Old May 27, 2007 | 03:17 AM
  #164
SinCityG35's Avatar
Terrycs,
Is your car crooked? I looks lower on the driver side. Also the alignmnet specs you gave of your car are uneven and railgunners was even with the H&Rs. Here is your quote that leads me to belive your car is not perfectly level from side to side, "My car (before camber kit) was -1.7 / -1.4. Railgunner’s car was -1.6 / -1.6. " your car was .3 different from side to side both on the front and the rear. That would lead me to believe it is not an even drop. Can you measure to confirm?
Old May 27, 2007 | 11:58 AM
  #165
DaveB's Avatar
FYI, since the 2nd gen chassis and basically a slightly modified chassis, I don't why all the rear suspension adjustment peices are necessary. I'm running coupe springs in rear of my 03 G35 and have about .75 degree more camber than stock. I've been running this setup for about 2 years now with absolutely no wear problems in the back. However, the Z springs in the front have caused some very slight inner wear over 6K miles, but once the tires are swapped to the rear, wear becomes uniform again. I guess my point is, if you're not experiencing significant wear in the rear, then I'd consider passing having to modify your rear subframe and spending all the extra money to put it back to OEM specs. With this chassis, you need to be more concerned about the front alignment, not the rear. Seeing that the 2nd gen has the same ride height as the 1st gen, I'd be VERY concerned about any spring that lowers the car more than 1" because after 1" is where all 1st G35s start to see really extreme front tire wear especially with wider than stock tires/rims. The only way to correct this problem is with expensive A-arms.
Finally, anything more than a 1" drop on stock shocks is a no-no because the shocks are not valved for that operating range nor the spring rate when the progressive springs go into their stiffest setting towards the last 50% of compression. Progressive rate springs like Eibachs are good for looks and initial ride quality, but not really good for all out performance because they're initially soft and then quickly firm up which can give poor at the limit handling characteristics. The larger drop also compromises suspension travel which is really bad because the suspension will be hitting the bump stops far more often which is never a good thing.
