What tires come on the Sport?
Old Mar 19, 2007 | 02:30 PM
timn99's Avatar
1. Brand and model?
2. Since they are staggered, how about rotation?
3. Anybody changed to a high-performance all-season, for the people in the northeast US?
Old Mar 19, 2007 | 02:55 PM
hothothot's Avatar
Bridgestone Potenza RE050A
Can't
N/A - I'm in Phoenix, there's more than 1 season?
Old Mar 19, 2007 | 03:00 PM
Tiger's Avatar
You can rotate side-to-side, right?
Old Mar 19, 2007 | 03:05 PM
Christian's Avatar
No the tires are directional.
Old Mar 19, 2007 | 03:12 PM
Tiger's Avatar
Are you sure? It looks to me like they are Asymmetrical.
Old Mar 19, 2007 | 03:16 PM
CardsDG6MT's Avatar
Originally Posted by timn99
1. Brand and model?
^^^ +1 on questions 1 and 2.
To your third question though... I have a wheel set with snow tires for winter here in the MidWest. Small price to pay for enjoying high-performance rubber 9 months of the year.
Old Mar 19, 2007 | 03:19 PM
CardsDG6MT's Avatar
Are you sure? It looks to me like they are Assymetrical.
Or asymmetrical
http://www.tirerack.com/tires/tires....Potenza+RE050A
Old Mar 19, 2007 | 03:20 PM
Tiger's Avatar
Yea, sorry about the spelling! I was correcting it while you were typing!
Asymmetrical means that you have an "inside" and an "outside". They can rotate either way.
Old Mar 19, 2007 | 03:24 PM
CardsDG6MT's Avatar
Just couldn't pass that easy one up..
I included that link to TireRack.com because it does state that the tire is asymmetrical... regardless of the spelling.
Old Mar 19, 2007 | 03:34 PM
max2k1's Avatar
1. Brand and model?
No rotation -- no side to side either (directional)
This is clearly mentioned in the owner's manual.
Old Mar 19, 2007 | 04:19 PM
EWG35's Avatar
You can dismount the tire and move to the other side. Which is actually better anyway. If the inside or outside is wearing and you simply remove wheel and bolt it on the other side, unless your alignment is way off on the other side you'll get a similar wear pattern. Therefore it's almost not worth rotating unless you dismount and put the dirty side of the tire "out" on the other side. That will cost you about $100 each time though.
Old Mar 19, 2007 | 04:22 PM
Tiger's Avatar
You absolutely cannot do this, because the tire is asymmetrical. There is an "inside" of the tire and an "outside"!!!
Old Mar 19, 2007 | 04:48 PM
sjharris's Avatar
none of this applies to the x does it? i assume all 4 tires are the same and i can do a normal rotation.
Old Mar 19, 2007 | 04:55 PM
Christian's Avatar
The owner's manual states:
"Tire rotation (18-inch tire models)
Tires cannot be rotated on this vehicle, as front tires are a different size from rear tires and the direction of the wheel rotation is fixed for each tire."
Old Mar 19, 2007 | 05:12 PM
SPEEED's Avatar
Bad Toro
A/S will be sub-par. If you want to get to your destination safely, get yourself a winter set mounted on a separate set of wheels.
