Wheel question on G35 Sedan - Lexus Rims
I need advise fellas…..I am looking to get a G35 sedan very soon. I have a set of chrome Lexus GS350 rims. They are 18 x8 with an offset of 45. Same bolt pattern, as g35 I think, but I am concerned, is the center of the hub or whatever bigger on the G35 such that this rim will not fit on properly ???? take a look at these….Thanks in advance
I googled lexus center bore and they are 60.1 Nissan/Infiniti wheels are 66.1 so OEM Lexus wheels will not fit on a Infiniti/Nissan but Infiniti/Nissan wheels will fit on a Lexus.
Guest
Posts: n/a
First Post!
I had this same problem today! I couldnt fit a 20" wheel made for a lexus onto my '03 g35 sedan. I know its because of the center bore issue like yall said. My question is how to get around this problem. Can I use a 10 or 15mm spacer to go over the center and even out the surface of the hub? The wheels I have are 42 offset up front and a 48 offset in the rear so I know I can push them out a little without rubbing issues? Is this correct? Btw they are 20x8.5 f and 20x10r. Thanks in advance!
The spacer will not help you. It will fit over your center bore but the wheel itself will not.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
BlackGee35
Jul 23, 2015 01:36 PM
