19' M45 Wheels on a 07' G35x
I know there were fitment issues on the earlier sedans. But I was wondering if anyone could tell me if they would work on a 07'.
From what I know, the factory wheel specs on a 06-07 m45 are 19x 8.5 and run a 40 series tire. I figured this would be a great combo for the X, since we can't run a staggered setup. The only problem I'm seeing is that they a 50mm offset. (Factory G35X are 17" x 7.5" +45mm)
I would really like to make this work, since it's a great looking wheel and there are some real deals to be found.
For those who are unfimilar with what I'm talking about, heres a link to the wheels:
https://g35driver.com/forums/archived-sales/154483-fs-19-infiniti-m45-wheels-tires-less-than-500-miles-1800-obo.html
Please let me know your opinions!
https://g35driver.com/forums/showthread.php?t=154483
Yeah, I know it's been done. I just was under the impression that the "ideal" offset for the 07' was different than the previous years. Therefore I wasn't sure if spacers would still be needed.
Otherwise if it's the same, I guess I have my answer.
I think the M45 19s are a great looking wheel. They would look sweet on the 07.
The offsets of the M45 rim are 50mm. The offset of the rear Sport 18" wheel is also 50mm. I think if you run a 10mm spacer in the front with the M45 wheel and no spacer in the back , it would be perfect.
Just to confirm, using a spacer on the G35x shouldn't affect the awd system then? All that matters, is that the wheels and tires are the same.
Thanks for the input!
I would run a spacer in the back too so they don't look so tucked in. If anything run a little larger spacer in the rear.
^ Topic has been discussed many times some just don't feel comfortable with putting spacers on their cars but hubcentric spacers and lug extension bolts on a stock wheel that's already 66.1 is the best route it'll cost you more for the hubcentric spacers though. Look for a quality brand and the best bet is to post in the main tech area for brands to get an idea from those that have used the hubcentric spacers for a long period of time.
Originally Posted by shaneotool
The wheel fitment for previous G35 sedans and the 07 G35 sedan is the same.
I think the M45 wheels look great on the G.
Cajuncowboy
Jun 21, 2021 09:47 AM
Jiggerjuice
Aug 17, 2015 08:41 AM
