18x7.5 et45 (F) and 18x8.5 et50 (R).. what spacer size to make them 'flush'?
Old Oct 17, 2007 | 01:07 AM
KCMO's Avatar
What size spacer is needed to make the stock sport wheels/tires sit 'flush'?
They're 18x7.5 et45 (F) and 18x8.5 et50 (R)...
15mm f/r or 20mm f/r or a mix?
http://www.conceptzperformance.com/C...3969.76.220.77
Old Oct 17, 2007 | 01:39 AM
AlterZgo's Avatar
I'd go +20 F and R if you're lowered and +15 F and R if you're not lowered.
Old Oct 17, 2007 | 12:08 PM
Wei's Avatar
Wei
skinny wheels, need to add an inch to both (width wise)...
Old Oct 17, 2007 | 01:12 PM
KCMO's Avatar
*edit*
nevermind, i just figured out how offset numbers work. lol
18x8.5 et50 w/ a 20mm spacer = 18x8.5 et30. I wasn't sure if it moved in or out as et increased decreased.
this is a cool little tool http://www.1010tires.com/WheelOffsetCalculator.asp
Looks like 20mm w/ a drop would be perfect.
Pretty much the same stance as this: (20mm front / 19mm rear)
https://g35driver.com/forums/media-share-v36-sedan/173844-my-07-finally-rims-drop.html
marsman328
Northern California
Aug 11, 2015 07:29 PM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Cam_Cooper3
Aug 4, 2015 01:53 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
