Stock Wheels That Fit
Old Nov 18, 2007 | 07:42 AM
JayJay's Avatar
This thread is just to clarify the stock (OEM) Nissan/Infiniti wheels that will fit an 07+ G without problems clearing the brakes or anything else for that matter.
Please feel free to add wheels that fit. Bolt Pattern for G's are 5 x 114.3
Non-Sport Model (G35X)
G35 17" wheels
M35 18" wheels
FX 20" wheels
Sport Model
03-06 sedan 18" wheels
06-07 g35 coupe 19" wheels
03-05 350z 17" wheels
05-06 350z Grand touring 18" wheels
04-06 Maxima 18" wheels
M35 18" wheels
M45 19" wheels
g37 19" wheels
Here is a list of some of the offsets of some Nissan/Infiniti wheels:
Nissan:
17" x 7" 00-03 Maxima SE 45mm
17" x 7" 02/03 Maxima 40mm
18" x 7.5" 04/05 Maxima
18" x 8" 350Z 30mm
Infiniti
17" x 7.5" Q45t 30mm
17" x 7" I30t 45mm
17" x 7" I35 40mm
17" x 7" I35 sport 45mm
17" x 7" G35 45mm
17" x 7.5" Q45 40mm
18" x 7.5" Q45 45mm
18" x 7.5" M45 35mm
18" x 8" G35 coupe 30mm
Old Nov 18, 2007 | 02:20 PM
B L U E S L A T E's Avatar
Honda Accord
I've heard/seen that 19' G37 wheels fit 07~08 G35 sedan.
Old Nov 18, 2007 | 02:57 PM
JayJay's Avatar
List updated
Old Nov 22, 2007 | 01:27 PM
dj2dj2's Avatar
Hi,
Sorry, Im new to the G35 Family and just purchased a 08 G35X. I was seriously considering putting 19" M45 rims on my G but didnt know if they would fit.
I had 2 questions for you since you sound like the person who knows what they are talking about. First, is there a difference between the 08 M35 and the 08 M45 rims? And second, will they fit on a 08 G35X? If they will fit, will I need any spacers or anything?
I appreciate your time. thanks.
dj
Old Dec 6, 2007 | 07:21 PM
TT C6's Avatar
I'd like to know if you can fit the following wheels at all 4 corners of the 07+ G35x:
07+ G35 18" Sport Sedan (Rears)
08+ G37 19" Sport (Rears)
08 350 Z Grant Touring (Rears or Fronts)
08 350 Nismo (Rears or Fronts) Part# for pics=4030S-RN89210
Old Dec 7, 2007 | 09:47 AM
celwin's Avatar
Update the list with the following
03-04 sedan sport wheels fit the 07 G35S. I'm running those right now for winter wheels.
Old Dec 29, 2007 | 12:38 AM
JCFW's Avatar
Sorry pal, for the X, you need to have all 4 whells the same width, so technically no staggered setup. Also the nismo will not fit an x model, since i looked into the nismo also, and if l remember correctly, the set of rims are staggered, and even if you can get (ie. all 4 front rims) the offset still will note work. if u want rims for the x, call up Chris @ F1 (see the marketplace) he hooked me up with some nice rims for my X.
Old Jan 2, 2008 | 01:58 AM
TT C6's Avatar
Thanks for the advice.
But, I'm OEM or nothing on my daily driver.
I will do either A. or B. on my G35x.
A) OEM set of G35 rims from either a 07 G35 Sport Sedan or G37 Coupe
- or -
B) 4 of the same (4 front, or 4 rear) all the way around from an 07 G35 Sport Sedan or G37 Coupe.
Can anyone else verify if I can or cannot do either A. or B. ????
If I can't do either, I will just leave the stock OEM rims on my G35x.
Old Jan 28, 2008 | 11:42 PM
Shakey's Avatar
Will 17" 03-05 G35 5AT (Non-brembo) Rims fit on the 07 Models with the performance brakes?
Old Jan 30, 2008 | 12:46 AM
EG3's Avatar
EG3
Hi
Im Look for help with rim & tire set up
Im putting 18x7.5 wheels on my 08 Gx
and putting Goodyears F1 a/s... my question is , What size tire should I go with.... I want a low profile( not to low.. no rubber bands ).
I was thinking 225/45, 225/40, 235/45 or 235/40? or any suggestions?
much appreciated.
anyone one where from north side of the chi?
Thanx for the help guys & gals
Old Jan 30, 2008 | 08:34 AM
Lemodular's Avatar
Thanks for this list JayJay3452.
The 07 have a Journey package that is not an "X" and can be fitted with Sport model wheels, so I assume all wheels fitting the Sport models should also fit the Journey. The brakes(rotors) in the Journey is about 1" smaller in diameter.
Why haven't this been stickied?
Old Jan 30, 2008 | 10:25 AM
snowcrossmxz's Avatar
EG3:
I would go with 235/40, its a little wider tire so it has more rubber on the ground
Old Jan 30, 2008 | 12:27 PM
EG3's Avatar
EG3
Thanks for your response but will the 235/40 leave to much space in the wheel well? im putting on 18
Old Jan 30, 2008 | 01:08 PM
That all depends on what kinda look you want.
235/40's have a side wall that measures 9.4 centimeters from rim to tread.
this might help
http://www.miata.net/garage/tirecalc.html
Forward Message
Old Feb 14, 2008 | 02:44 PM
G-Me's Avatar
this might help
Forward Message
Very helpful site... thanks!
