What size rotors come stock on the 07' sports for the Front and rear?
Will 14.25'' rotors fit with a 20'' wheel on the front?
Looking at the brake pros brake systems for the sedan and just wanted to know if i should get the 13'' in the front or 14.25''.
Thanks
Thanks
Hmm..I am pretty sure the Sports Package G come's with 13 inch brakes front and rear. and the Reg and Journey ones come with 12inch rotors front and back.
Texasscout
close
- Join DateFeb 2005
- LocationSouth Texas
iTrader Positive Feedback100
iTrader Feedback Score(11)
Liked:2,116 Times in 1,768 Posts
Just checked the Infiniti site : http://www.infiniti.com/g_sedan/specifications.html
MT6 Sport
13.0" X 1.3" front
13.0" X 0.6" rear
G35, Journey, X
12.6" X 1.1" front
12.1" X 0.6" rear
MT6 Sport
13.0" X 1.3" front
13.0" X 0.6" rear
G35, Journey, X
12.6" X 1.1" front
12.1" X 0.6" rear
A 14.25" rotor will fit in 20's, may even fit in 19's
Wheel offset and caliper-spoke clearance will be a bigger issue. I think you could fit a 15" rotor/BBK under 20's.
yea wheel off set might be a problem. Ill just have to call the tech guys there and see whats up
you must make sure to get the correct PAD height on the wheels you purchase...
Most likely the wheels you are getting will have to be a HIGH PAD wheel or VERY HIGH PAD due to the offset of the caliper...
BTW - OEM G37 BRake Kit front and rear $2195 shipped to you in florida... (includes calipers, pads, rotors, etc etc)
