Tire sizes/ fitment...
Old Feb 24, 2008 | 05:44 AM
longbutthair's Avatar
Hello all. I have a question about tire sizes as I don't know much about this topic. I have the '07 G35S with the staggered tires fitment. The original sizes offer little choices. I was wondering if there is an advantage/ disadvantage of having the rear tire a lot wider than the front tires. I was looking at possibly 225/45/18 front & 255/45/18 rear. Is the rear too wide, or should I stick with the original 245?
-David
Old Feb 24, 2008 | 08:58 AM
snowcrossmxz's Avatar
im going 275 in the rear. u get better traction with a wider summer. Also you get better curb rash protection.
Im selling the stock OEM set of tires for the G35S, they only have 400 miles on them if ur interested.
Old Feb 24, 2008 | 01:22 PM
AlterZgo's Avatar
Increasing rear tire width won't do anything bad per se, but the car will understeer a bit more as the rear will be more planted. 255-45-18 may also have a slightly negative impact on acceleration because of increased weight and taller gearing (255-45-18 tires are taller than 245-45-18s).
If you want to stick with 225s up front, you should stay with the stock 225-50-18. Going to a 225-45-18 would make the front tires shorter which will make the front wheel well gap look even bigger than it is. Paired with the taller 255-45-18, your car will be raked forward with the back end looking a bit raised and the front end dropped.
If you want to have more tire size choices, I'd recommend going up to 19" rims/tires. You can then run the popular staggered 245-40-19 and 275-35-19 or just run 245-40-19 all around.
Old Feb 24, 2008 | 05:25 PM
Thanks AlterZgo for the info. Really appreciated. 225/50/18 will only allow me the choice of the stock Potenzas or Goodyear Eagles. Would you suggest any other sizes since I intend on staying with the 18" rims? 245/45/18 aren't as hard to find.
Old Feb 24, 2008 | 07:22 PM
blnewt's Avatar
Quite a few are going w/ 225/45/18fronts and 245/45/18rears without problems.
Old Feb 25, 2008 | 02:40 AM
CoppellStereo's Avatar
what is the widest tire that will fit on the rear stock sport rims? i want something wider than 245
Old Feb 25, 2008 | 04:17 AM
hyukki's Avatar
http://www.rims-n-tires.com/rt_specs.jsp
Old Feb 25, 2008 | 12:47 PM
meandeane's Avatar
im running 225/45 front and 245/45 rear and i haven't noticed any changes in handling, the difference between 225/45 and 225/50 isn't all that much
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
philthethrilloh
Sep 9, 2015 01:25 AM
socaldavid
Sep 5, 2015 04:35 AM
