Help: Rusted Brake Rotors
Old Mar 6, 2008 | 08:17 PM
zillmc's Avatar
Hey all,
I purchased an '07 G35S 6MT last February (2007) and about 4 months ago I started seeings rust buildup on my brake rotors where the brake itself isn't touching. I'm not sure if anyone else has had this issue, but it's really starting to bother me as it kinda makes my car look trashy. I talked to my dealer about it briefly and they said that it was fairly normal but I didn't have them take a good look at it when I brought it in for my last services.
Basically, on all four wheels (most noticeable on the rear), there is a circular buildup of orange rust. It's my understanding that this probably shouldn't happen for at least a good 30k-60k miles. My car is just over a year old now and it seems odd that I have this problem. Is this normal or is anyone else experiencing this? I will post some pics when I get home from work.
Just some background information, my car has been mostly garaged since I purchased it. It sits outside sometimes when my brother takes the garage for his 335i. I live in a relatively moderate climate (bay area, california) where there is moisture in the air but not nearly as bad as some coastal areas.
Anyone have any tips for removing this rust buildup or can provide some insight if I should be more concerned or if theres some greater root problem? Thanks in advance for any response!
Old Mar 6, 2008 | 08:30 PM
ABQ_G35's Avatar
Sounds normal to me, especially where you are located. If you notice when you wash your car, there is always a light coating of rust on the rotors, as soon as you drive the car, it disappears!
Old Mar 6, 2008 | 08:35 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
It's normal....
Zinc plated rotors will stand up a little longer, but it's inevitable.
Old Mar 7, 2008 | 03:44 PM
imnotplutonium's Avatar
agreed
Old Mar 7, 2008 | 11:04 PM
johnnyzee's Avatar
true, this is normal and nothing to fear. Once you brake, the rust will come off. perfectly normal
Old Mar 8, 2008 | 04:53 PM
BlkG35Sport's Avatar
drive more worked for me.
Old Mar 8, 2008 | 05:04 PM
Andy2434's Avatar
To eliminate the rusty look on the non contact portion of rotors, you can opt to spray the entire surface of both sides of the rotors with a high temp paint. Once the brake pads make contact with the rotors, the non contact portions will remain protected by the remaining high temp paint.
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
heynow
2nd Gen (V36) Sedan
Oct 28, 2015 05:09 PM
Mhacker
Sep 12, 2015 07:35 PM
NJ6MT
Sep 10, 2015 08:40 AM
3000vr4tt
Sep 7, 2015 12:48 AM
