How to turn off the tire pressure light off
Old Apr 8, 2008 | 09:17 PM
hsp_14's Avatar
Hi guys im a new 2007 g35s owner and I just change my wheels and the tire pressure tire immediately turned on and i have no idea how to turn it off... can anybody help?
Old Apr 8, 2008 | 09:37 PM
kool_yaar's Avatar
As far as i know, and have researched(A LOT!!!!!!!!!!!!!) there is still no way to disable the light other than taking out the bulb. What did was to transfer the TPMS into my summer wheels and run the winter without 'em that way i have to bear with the light for 2months out of 12.
G/L
Old Apr 8, 2008 | 09:38 PM
Mr.GEE's Avatar
20 Year Member
Did you replace your wheels? If so, did they transfer the TPS located inside the wheel tire valve stem, from your original to the new wheels? The other option you have is to remove the bulb from the dash TPS light.
Old Apr 9, 2008 | 12:15 PM
hsp_14's Avatar
Thank you for the reply guys, by the way its not an option for me to remove the light ... so probably can i just go to a discount tire or le swharz to transfer the tps?
Old Apr 9, 2008 | 01:05 PM
ttrank's Avatar
Grocery getter
Yes you need to transfer the sensors. It's a safety system so you can't get around it. My local discount won't even put aftermarket wheels on peoples cars without moving the sensors over.
Old Apr 9, 2008 | 01:07 PM
cremaster's Avatar
when i called the dealer, they told me to remove the fuse associated with it to disable it. however, i could not find this mystery "fuse."
Old Apr 10, 2008 | 02:10 AM
hsp_14's Avatar
actually i change the wheel myself that is why i dont know about this mystery fuse. this means i can go to a discount tire and just transfer it right?
Old Apr 10, 2008 | 09:24 AM
mossman's Avatar
Is there a fuse just for the TPMS?? Somehow I highly doubt they would put it on a separate fuse. I am still looking for a way to disable the TPMS. I am sure lots of you are
Don't have the time to research this much.
Mry
Mar 3, 2023 01:03 AM
ghost_g35
Aug 7, 2015 10:31 AM
attarday
Jul 15, 2015 04:03 PM
