Brake Pads
Old Apr 30, 2008 | 10:10 PM
IsaG35's Avatar
Brake Pads
I have been having brake problems with my car since day 1 and taken it do the dealer everytime.. now they claim I need new pads..
I do not want the OEM pads again so I am looking for suggestions for some good upgraded brake pads that are not too pricey.. any suggestions?
Old Apr 30, 2008 | 10:56 PM
G35Now!'s Avatar
Moderation-free
How many miles do you have on your G? I was surprised at 17k miles to still have about half of the pads left, especially since I drive pretty hard. The stock pads seem to work pretty well, are you sure it's a pad problem? What specifically are the brake problems you've had?
Old Apr 30, 2008 | 11:23 PM
IsaG35's Avatar
I have 24k miles on the car. They resurfaced the rotors at 17k but put the same pads back on which has 50% at the time. They said they have 30% left now.
I have had this vibration problems in the steering wheel when I brake around 40mph and they tightened the calipers once, and then did the resurfacing the 2nd time. That problem never truly went away.
Now however when I brake I get this really loud grinding noises.
Old May 1, 2008 | 12:32 AM
Pdubz's Avatar
yeah.. i kinda feel the vibrations too.. but it doesn't squeak.. u think i need mine changed? i have about 25k on it
Old May 1, 2008 | 01:13 AM
hyukki's Avatar
I have like 1% left @ 41.5k... lol.
At least it seems like that to me.
Old May 1, 2008 | 10:05 AM
G35Now!'s Avatar
Moderation-free
Ouch - yep, sounds like new pads to me. Unfortunately, not sure that pads are your vibration problem, that does sound like rotors despite the fact they've already been turned once.
Good luck!
Old May 1, 2008 | 01:47 PM
win2456's Avatar
one of the rotors maybe warpped?
Old May 4, 2008 | 11:35 PM
The Critic's Avatar
Pedal pulsation is caused by disc thickness variation. Excessive runout is one cause of excessive disc thickness variation, which leads to pedal pulsation complaints.
In the first generation G35, the maximum allowable rotor runout is 0.0014" for the front. Many cars allow up to 0.003." In other words, the G35's front rotors are extremely sensitive to runout. Therefore, if you install new rotors or have the rotors resurfaced using a bench lathe, it is very important to check the runout after installing the rotor.
You can check the runout using a dial indicator. If the runout exceeds specifications, you need to rotate the rotor's mounting position one hole at a time to see if you can minimize the runout. If that fails, then you'll either have to use runout correction shims or have the new rotors resurfaced using an on-the-vehicle lathe.
When you mean upgraded brake pads, what are you looking for specifically? Lower dust? Longer life? Better performance? Usually you will have to give up one thing for the other.
Old May 5, 2008 | 12:17 PM
NationsMostWanted's Avatar
rotors
Old May 5, 2008 | 05:30 PM
JayJay's Avatar
OFF TOPIC!
41,500 miles already You really love your car dont ya!
Old May 5, 2008 | 05:54 PM
RowanBuds's Avatar
Sorry to borrow the thread.
I have the pulsating issue going on as well. I have just over 6K on the car. Im under warranty, would that be something that is covered, my rotors DEFINATELY should not be warped after 6K. The car has never been on a track, and only a handful or two of hard stops in its lifetime.
Anyone with $0.02 to add to my situation?
Old May 5, 2008 | 10:46 PM
IsaG35's Avatar
I have the pulsation problem on the steering wheel and not on the brake pedal.
Old May 5, 2008 | 11:33 PM
rebalance tires if steering wheel shakes without brakes applied
Old May 6, 2008 | 06:58 AM
pitman123's Avatar
i have the pulsation at 7800mi also. when the rotors heat mark (blue) the metal changes and no matter how many times you cut them it comes back. the more you cut the less metal to dissipate heat, the more prone to warping. the only way to go with cutting rotors is an on the car lathe. they automatically adjust to the hub. then you are guaranteed minimal runout. im highly dissapointed with the rotors on this car.
Old May 6, 2008 | 12:56 PM
popcornten's Avatar
I had this problem on my previous car, a BMW 5-series. There was heavy vibration through the steering wheel when decelerating from highway speed. It ended up being a warped rotor as well, so you guys will probably need at least 1 new rotor
