350z springs on 07 g35x
Old May 29, 2008 | 10:07 PM
beyd7's Avatar
I am looking into purchasing slightly used '08 350z springs.
Can't find any exact answers to these questions:
-any idea as to what the drop will be?
-will they ride be rough?
-Will it mess with my camber? AWD?
and in general, What is everyones thought on this setup?
Thanks.
Old May 30, 2008 | 02:31 AM
CalsonicVQ's Avatar
Revised 350z springs were tried before on a non-X. Rear lowered ~1". Front surprisingly was the same. But keep in mind that X's are a bit higher from the factory.
Old May 30, 2008 | 12:21 PM
beyd7's Avatar
That is exactly why I want to lower it. It looks like a 4x4. I would even go with stock 07 sport springs but I don' think the small difference is worth it.
The 350z springs should be ok I just hope they don't mess with the attessa awd system.
Old May 30, 2008 | 06:52 PM
CalsonicVQ's Avatar
Sorry, I should clarify. When I said the rear lowered ~1" and that the front was surprisingly was the same, I meant that the front height after the 350z springs install was the same as stock height (i.e. no drop).
Old May 31, 2008 | 09:31 AM
beyd7's Avatar
wow. That sucks. I figured that they would definately lower it since g35x looks like its riding really high and the z looks so low to the ground. I was going to purchase the tanabe but they suffer a similar problem. The rear drops lower than the front.
Thanks.
Old Jun 4, 2008 | 01:12 PM
nr2134's Avatar
I had a 05X with unrevised Z springs and it lowered the car front and back. The front was not extreme and it did make it look better...no to mention handle better also. Those springs were rough though. Spring rates were higher than X, but thats what I wanted.
Old Jun 5, 2008 | 05:15 PM
Vir2L's Avatar
If the springs work on a 07g35x then would shocks be compatible as well?
johnadlertech
Lights
Sep 4, 2015 12:35 PM
kevintandmd
Sep 3, 2015 06:41 PM
