Infiniti OEM rims
Old Oct 14, 2008 | 01:33 AM
BrendanS's Avatar
Infiniti OEM rims
hey guys,
My moms looking to get a set of winter wheels so I found some Coupe 18s. They 7 spoke ones. I just wanted to double check to make sure that they fit. Also, which infiniti rims wouldn't fit, that way I can avoid them.
Brendan
Old Oct 14, 2008 | 08:27 AM
snowcrossmxz's Avatar
there is a post around here for this.
search for it
Old Oct 14, 2008 | 08:56 PM
BrendanS's Avatar
Just searched through 8 pages, I didn't find the specific answer, I know the coupe 19s fit. But I just want to make sure the coupe 18s fit.
Old Oct 17, 2008 | 08:45 PM
G force's Avatar
I bought a snow set-up off a guy with a first gen coupe. Its an ASA rim with snow tire set-up from tirerack, and I was concerned the off-sets would not work on an 07 sedan. The bolt patternsbhg are the same, the offsets are a little different between gens. I assume the guy I bought them from used the same offsets as 1st gen OEM coupe. They ended up fitting on my 07 sedan. They do not stick out past the fenders and dont rub since there is lots of wheel gap on a stock height.
Old Oct 17, 2008 | 08:47 PM
snavematt's Avatar
just a sedan
if 19s work why wouldnt 18s?
Old Oct 18, 2008 | 07:16 PM
jsmonet's Avatar
your logic is slightly backwards here
when you go smaller you run into the possibility that things like the offset, and clearance from the caliper to the inside wall of the rim end up a tad incorrect. seeing how the 2nd gen has relatively large discs and calipers, that clearance (a measure of both inner diameter and offset) could be a problem.
it may not be an issue in this case, but it never hurts to ask.
Old Oct 18, 2008 | 08:34 PM
snavematt's Avatar
just a sedan
that makes sense
yellowshirt
Wheels & Tires CDN
Apr 8, 2018 06:09 PM
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
multimut
Canada
Jul 26, 2015 08:43 PM
CrazyLogic219
Jul 23, 2015 10:58 AM
