Front and Rear Camber Kits
Old Nov 6, 2008 | 11:07 AM
KulG35's Avatar
Is it really almost $600 for rear camber and another $200ish for front camber kits for our car?! I remember my Acura it was like $200 for front and rear! Anyone know where I can get front and rear camber for the best price?
Thanks!
TK
Old Nov 6, 2008 | 05:55 PM
baileyt35's Avatar
Dang!!! So glad I'm waiting to lower. Crapola, that is way too much!!! Now trying to jack your thread but who makes front/rear cambers for the G?
Old Nov 6, 2008 | 06:00 PM
KulG35's Avatar
stillen is the only I know of personally....
Old Nov 6, 2008 | 06:02 PM
Rival's Avatar
SPC front and rear shipped $525. Check Market Place/ vendors for deals.
Old Nov 7, 2008 | 01:15 AM
terrycs's Avatar
No fronts yet for the 07+.
T .. you can call SPC and see who carrys them near you or online.
Some more info here since you are in OC:
https://g35driver.com/forums/souther...camber-oc.html
Old Nov 7, 2008 | 05:17 AM
G35Robby's Avatar
we need some front cambers damnitttt
spc is really expensive thought
eibach has camers for our cars but only the rear
Old Nov 10, 2008 | 06:00 PM
KulG35's Avatar
They don't have the fronts yet... I was told another week or so. They have two options for the rear. One is just 2 bolts for $54.94 and they adjust up to 3 degrees and the other option is 2 bolts plus the arms for $193.10 and they adjust up to 4 degrees.
Seems weird it's just 2 bolts, I can't imagine my camber being more than 3 degrees and if I can get away with 50 instead of 200? What do you think?
Old Nov 10, 2008 | 11:28 PM
terrycs's Avatar
Let me clarify, if you get the kit from Eibach, one will have camber arms and toe bolts for the rear. The other is toe bolts for the rear ONLY. You need the one with the camber arms (expensive one). The toe bolts obviously come with it.
Old Nov 11, 2008 | 12:07 AM
KulG35's Avatar
No... both are from SPC, both are for the rear.... see links:
Amazon Amazon
this is the bolt and arm which allow up to 4 degrees adjustment
Amazon Amazon
this is just the bolt which allows up to 3 degrees adjustment.
Both are by SPC and for the rear, just one allows up to 3 and one up to 4 degrees. The front camber from SPC will be released in the coming 1-2 weeks
Old Nov 11, 2008 | 12:22 AM
terrycs's Avatar
http://www.amazon.com/Specialty-Prod...6379941&sr=1-4
http://www.amazon.com/Specialty-Prod...6379955&sr=1-3
One is TOE adjustment, the other is CAMBER adjustment. The kit with both parts do both camber and toe because you get both parts. I suppose the camber and toe are related to a certain extent, but I don't know how they got 3 degrees of camber adjust from the toe bolts alone. You should call SPC to be certain. Also, SPC is Eibach's supplier.
The camber arms are what most people get, but some do not bother installing the toe bolts.
Old Nov 11, 2008 | 12:09 PM
KulG35's Avatar
Looks like the arms for me... SPC said that they both do the same, but what you said makes much more sense.
Old Nov 12, 2008 | 05:41 PM
bfranks's Avatar
THMortorsports are starting a group buy on the front camber kits on myg37.com.
Check out this thread if you are interested.
Old Nov 12, 2008 | 05:53 PM
Eug96's Avatar
noob question...Is a camber kit 100% nesessary if i am going to lower my G?
Old Nov 12, 2008 | 05:56 PM
bfranks's Avatar
Depends on how low you go, and how often you want to replace your tires (due to uneven wear).
Old Nov 12, 2008 | 07:07 PM
KulG35's Avatar
I'm #3 on preorder
