brake replacement
Old Nov 12, 2008 | 04:43 PM
suby01's Avatar
brake replacement
so its time to get new pads 18k miles because my brakes vibrate and shake under hard braking. i have a question on the G's do we need both front and rear sets or does the back or front wear faster?
havent really had a car with disks all way around. and the dealer wants 75$ each stillen has them for 50-60$. suggestions?
Old Nov 13, 2008 | 11:16 AM
CASEY1's Avatar
Changed front and rear pads yesterday. OEM Infiniti pads cost $90.00 plus shipping. Car has 34,000 miles on it. Rear pads were almost done, front pads had maybe another 6-8 k left. Rotors were fine.
Old Nov 13, 2008 | 01:04 PM
ThiesG35s's Avatar
You use 80% of front brakes on any car. If your getting vibration, its the rotors not the pads (warping). Not to say, your pads probably need replacement but it wont fix the problem. Your new pads will also wear out quicker if the rotors are warped. With that many miles, you should have them resurfaced...no need to buy new unless you want to upgrade to a BBK.
Old Nov 13, 2008 | 01:13 PM
suby01's Avatar
so you say keep the pads? just get the rotors resurfaced and should be set?the pads still have a lot left on there..the brake light does come one once in a while meaning its low.
Old Nov 13, 2008 | 02:41 PM
kool_yaar's Avatar
if you're getting new rotors or resurfacing the old rotors, i would recommend getting new pads along with it, to avoid the rotors from being messed up agian, as the pads might have been glazed, cracked or not properly broken in causing premature decay of the new or resurfaced rotors.
jsimonk
Dec 22, 2023 03:49 PM
derres
Aug 28, 2015 03:27 PM
Patrick Bovee
Aug 7, 2015 11:16 AM
RedBaronK
Jul 27, 2015 03:19 PM
itschuckster
Jul 25, 2015 08:07 AM
