Stainless Steel Brake Lines
Old Nov 14, 2008 | 02:01 PM
Rizzagt22's Avatar
For those of you who have them installed on your 07+ G35 Sedan, is it really worth the money and is there a noticeable difference?
OR is it better to upgrade the pads/rotors?
Old Nov 14, 2008 | 02:14 PM
mIKE's Avatar
Stainless Steel brake lines will change the feel of your brakes.
Upgrading pads and rotors will improve performance and heat resistance (depending on pad choice of course).
What are you looking for? A stiffer brake pedal or more braking power?
Old Nov 14, 2008 | 03:20 PM
Rizzagt22's Avatar
I just feel like the brakes on my 08 journey lack bite and have the "mushy" feeling when I put my foot on the brakes. They also whistle a lot when slowing down from 40mph, but the dealer said they applied stop-squeal and dont hear any whistling.
A lot of the loaners I've driven which are 07 models, have good bite on their brakes. What do you reccomend Mike, I"m assuming your gonan say G37S BBK.
Old Nov 14, 2008 | 03:33 PM
mIKE's Avatar
If you're looking for more bite, get pads that have a stronger initial bite. If you want to reduce brake pedal travel, then get the stainless steel lines.
The BBK is for guys that drive a bit harder than the norm, or want the bling bling status, or both.
Keep in mind that the BBK is now standard on the 09+ Sports
Old Nov 14, 2008 | 05:45 PM
Rizzagt22's Avatar
What pads do you reccommend?
Old Nov 14, 2008 | 07:12 PM
LOW2000's Avatar
There is no drawback to SS brake lines, no compromise, only improvement.
Old Nov 14, 2008 | 09:17 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Not entirely true.
Get the lines that are coated & with sealed boots at the fittings.
Otherwise dirt gets into the braids & causes premature wear & failure.
The other thing with SS lines is when they do go, they rupture which = 0 brakes.
Regular lines get old and stretched & leaky, but they don't often completely fail.
Track cars change lines regularly.
Old Nov 15, 2008 | 01:36 PM
mIKE's Avatar
High stopping power?
Rotor Friendly?
Quiet?
Good Bite?
Low/High temp?
Remember, you can't get everything.
jilljann1
Jul 21, 2020 08:12 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
boostelevator
Brakes
Oct 5, 2015 08:56 AM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
