Tire Replacement/Upgrade for '08 G35x 17"
I just got a new '08 G35x w/ 225/55/17 GY Eagle RSA tires.
I read a lot of bad comments/reviews on these tires.
So I've been researching replacement of tires.
I like the looks of the OEM 17" wheels and will likely stay with that size.
I don't plan on lowering the car.
Looks like General Exclaim UHP is a good all-around tire for this car.
Are there better choices?
Is upgrading to 235/50/17 a good idea?
Indicated 60mph is actually 58.9 (1.8% fast).
Or should I stay w/ stock width/ratio?
Tom
Tom
To your question regarding GY Eagle RSA tires: My '05 came with GY Eagle Eagle RSA and at first I was disappointed with wear but I managed to squeeze 32K out of them. I just replace them with top of the line Michelin Pilot Sport A/S Plus and I'm not so sure that was a good move. The RSA's were very responsive side-to-side with a decent ride but the Michelin's seem soft comparatively; I get much more body lag & roll when attempting crisp lane changes and I'm not yet confident with high speed curves, and this from a Z rated tire. The RSA's were tight all around. The best review of the RSA will be your own. You might want to ride them out a while, if you want to stay with 55's then what's the rush?
I would not recomend general tires. And tire depends and what u want, there are different views of tires. Ones that grip better will wear faster pretty much, I work at firestone so some tires I can think of are Wide ovals, 960's, firehawk gt as far as all around.
Although I have an 07 Sport, my G is waiting to be picked up today with some new Pilot Sport A/S Plus's. I hated the F1's. I hope the PS A/S's handle better. If not I'm putting on Summer only's next time and dealing with the winter.
Double ACL: I agree with your assessment. I also discovered today on this forum some more info. The treadwear on the RSAs is 260 - not a great number, BUT the treadwear is affected by the compound used in the tire. The long the treadwear, the Harder the ride and maybe less handling abailities of the tire. Could make sense.I have RSAs on my 2007 G35X, with 16k, about half tire tread left. But the ride has diminished with the age; I leave them filled at 33lbs now, used to keep them at 35 lbs. MPGs are down too.
Tom
case in point, there was less than 0.25 inches of powdery snow on the ground, and i was turning left around a gentle bend @ 15mph. all of a sudden my tires lost traction and i slid into a pile of snow.
the handling is okay in rain, but the RSA's show their weakness when it snows.
my suggestion if you are in the snow belt, if $ allows, buy a dedicated summer/winter set. i guarantee you that you will feel the difference on dedicated tires.
My experience with GY Eagle RSA's having good handling comes from all central Florida driving - obviously no snow. So thanks G35xQX1 for the clarification. I didn't have any issues in rain, but as they are 225's anyway, I've been careful.
And yes Amatti, I too backed off the tire pressure to 30psi (which is the door sticker pressure) as I reached 25K & noticed the centers wearing way more than the outside edges. I picked up a little more grip but lost about a mile or per gallon.
Even at the lower pressure and with 32k miles, they still handled more crisply than the newly mounted Michelin Pilot Sport A/S Plus on my coupe (also at 30psi when installed). The store suggested we pump them up to 38psi to stiffen them up a bit (their rated to 51). I've noticed a slight improvement in handling while I'm very very happy with the smoother, quiet ride. So I'll probably accept that trade-off plus know that I'm getting a safer tire, especially if I ever travel to the great white north.
I think the stock 17" tires are just fine -- i live in chicago and they are good in the snow, just fine in the dry and wet... i never really push the G to the limits in the dry .. but it's not a sports car anyway, so why would i.
tire replacement
My 04 came with GY RSA's. Never liked them but wore the 04's to about 37K miles. Did a lot of research on tires and bought a set of
Yokohama V4S. Not only did these tires perform great but I got over 53K miles before replacement. Bought another set and they also ran great.
I just traded my 04 for an 08 G35X. Yeah, the car came with RSA's.
When these wear out, I'll be back to the Yokohama's.
I order a set set of General Exclaim UHP to be put on this week.
Tire got a lot of good user comments on TireRack for performance sedans (medium and high) like G35 and M3.
Hope they work out.
Tom
Hope they work out.
Tom
I have the same question, is a 235/50/17 tire able to be mounted on the stock 17" rims?
It would be nice Tom when you ask a question like this regarding tires, we knew what part of the country you live in. If you live in the warm states where you don't drive in snow you couldn't do better than Michelin's new Super Sports. The UTQG is 300 so they'll wear extremely well and will handle almost like the PS2s with near zero noise. Check www.Tirerack.com for best prices. My experience with Goodyear's I wouldn't put them on my Honda! (lawnmower)
Gary
Gary
