Low Tire Pressure in Passenger Rear Tire
Old Feb 10, 2009 | 01:42 PM
ugaexploder's Avatar
Hey guys, I noticed my tire pressure light came on in the instrument panel and didn't get around to taking care of it until a few hours ago...all the tires were fine except my rear passenger tire, it was at 12psi!!!!!!! i checked for possible gashes or holes, but nothing!...it just got really warm here but i didn't think that was gonna take 20psi out of my rear right tire...i'll give an update if there is something wrong with the tire, but i don't think that's the case...
Old Feb 10, 2009 | 02:43 PM
Borna's Avatar
You should double check and see if there's anything stuck in the tire.
I had the same problem last year and I checked for holes and gashes but found nothing so I just filled up and left it. About an hour later I was driving and the light came on again, took it to a shop and they found a big nail deep in (it was basically flush with the inside thread of the tire) so I had to replace it.
May as well check it out properly for your own safety.
Old Feb 10, 2009 | 04:06 PM
interesting, thanks borna! after work imma see if the tire is looking like it was earlier...if that's the case i better hurry with the wheels!
Old Feb 10, 2009 | 04:40 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
While your waiting for the wheels....
If its a nail hole, it can be plugged/patched temporarily if it's not near the sidewall.
Old Feb 10, 2009 | 06:13 PM
Borna's Avatar
No problem bro
Ian's right. Sadly I wasn't so fortunate and the puncture was right where the sidewall and tread meet (the tire place was baffled how it made such a deep hole in that spot (but of course this is Dubai where everywhere you turn there's a construction site lol
Good luck with it Paul
Old Feb 10, 2009 | 07:40 PM
i think you guys are right about the nail...the tpms light came on again but the tire seems like it has a decent amount of air left in it for me to take to a shop tomorrow...thanks to both of you guys
Old Feb 10, 2009 | 08:50 PM
G35Now!'s Avatar
Moderation-free
Make sure you air it up in the morning - tires with really low pressure tend to do bad things...
Old Feb 11, 2009 | 12:52 AM
Borna's Avatar
Anytime bro, just be safe and drive it slow cause if it's near the sidewall the tire could give out at higher speeds.
Post pics if you decide to throw on your wheels too
Old Feb 11, 2009 | 01:35 PM
i tried going up to bridgestone to get it fixed, but they didn't have my wheel lock key and i don't know where it is...they told me my tires are pretty much bald so it would be hard for them to repair it is what they said...this blows because some BS happened with my wheels and i had to wait an extra month...and im still waiting...where is the wheel lock key anyways?
Old Feb 11, 2009 | 01:50 PM
boss81's Avatar
either, glovebox, center consol or where the spare is
Old Feb 11, 2009 | 02:02 PM
InTgr8r's Avatar
WHeel lock?
I don't recall where it is when delivered.
But, FWIW..... I cut a hole for it in the plastic tool tray in the trunk.
It's with the wheel wrench etc when/if it's needed, & I don't have to remember where the hell it is.
Borna's Avatar
boss81 is right, it should be in one of those places
If you have to replace the tire without the new wheels then just try and get a hold of a used tire or something for cheap and use it temporarily till your wheels get in and then just throw them on with a brand new set of tires.
If the tire you get has more thread than the other tires then you'll feel a bit of vibration but it'll be ok since it'll be for a short period of time anyways.
Good luck with it Paul.
Old Feb 14, 2009 | 12:05 PM
The wheels+tires are in doraville, GA right now...too bad UPS doesn't ship on the weekends...i should have them on my doorstep monday, hopefully this tire will hold up for a couple more days
what does the wheel lock key look like anyway?
Old Feb 14, 2009 | 12:46 PM
boss81's Avatar
Sounds awesome Paul, post pics when you get them on ASAP!
Old Feb 14, 2009 | 01:18 PM
AesonVirus's Avatar
