Wheel and Tires: What do you think?
Old Feb 24, 2009 | 09:02 PM
  #46
boss81's Avatar
They did stick out further before the drop.
Old Feb 24, 2009 | 09:33 PM
  #47
terrycs's Avatar
Be systematic in your decision.
1) Decide if you want to live with added camber.
2) Decide on wheel width.
3) Decide on offset (if you get a choice as with DPE).
4) Decide on tire width (if you haven't been forced into a stretch after steps 1 and 2.
5) Adjust camber accordingly.
Step 1 is the most important because it obviously restricts your choices.
Old Feb 25, 2009 | 12:44 AM
  #48
KulG35's Avatar
Thanks Terry! I don't mind a little of camber just not crazy... wheel width I got, it's the offset I'm unsure about. I REALLY like your set up!
Old Feb 25, 2009 | 07:32 PM
  #49
KulG35's Avatar
Well, I think rim project is on hold until I can get the perfect rims... the cheaper route I'm find are causing fitment issues with what I want. Thanks for all your help, everyone that posted!
Old Feb 25, 2009 | 09:58 PM
  #50
2GoRNot2G's Avatar
No problem, Travis. Check around and see if you can find a decent set of used tires. I don't usually recommend buying used tires, but if you can find a decent set, then it may not be a bda idea to pick them up... they will save you bug $$, especially if you plan to replace them in the near future, and they should at least last you until you can save up for a full set of wheels and tires that you really like.
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
Mkhlmnn
V36 Interior, Exterior & Lighting
Feb 16, 2016 09:27 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
