Widest 20" rim for our sedans???
Old Feb 26, 2009 | 08:23 PM
beezy619's Avatar
Whats the widest setup we can run for our sedans? So far, the widest I've seen has been 07IMLG, running 20x9 38mm offset 245/35/20, 20x10.5 45mm offset 275/30/20. Is it possible to run coupe setups like 11" rears and low offsets?
Old Feb 27, 2009 | 04:21 AM
G35Robby's Avatar
11 is going to be really hard to run. You need like -3 0r -3.5 camber to run 11s
Old Feb 27, 2009 | 12:08 PM
beezy619's Avatar
Damn that really sucks....I keep seeing all these dope a$$ deals in the marketplace for rims, but they're mostly for coupes. Ok, here's another question....If I were to run a similar setup as 07IMLG, but for tires run 255/35/20 F and 285/30/20, would there be any issue as far as rubbing? I actually went to Discount Tire and they recommended running 255's in the front, but I know if you run the wrong tire size it could throw off ur speedometer.
Old Feb 27, 2009 | 03:42 PM
Borna's Avatar
I'd say 9.5 front and 10.5 rear would be the widest you can go without running too much negative camber and having to stretch.
If you run 255/35 and 285/30 on 9 and 10.5 inch rims you would probably rub without dialing in lots of negative camber. Running such wide tires on a car and dialing in lots of negative camber would be pointless since you'd have less contact patch anyways.
But those sizes wouldn't throw your speedo off much at all. You wouldn't even be able to tell the difference.
Could be wrong though. GP would have to comment on this.
Old Feb 27, 2009 | 04:37 PM
terrycs's Avatar
285 on a 10" wheel is no problem with camber in spec, but the offset has to be perfect. You can do more, but it will take some compromises.
Old Feb 27, 2009 | 04:40 PM
Borna's Avatar
Yeah but he's talking about 20x10.5 Terry,
I think he'd need to dial in a fair amount of negative camber. At least -1.5 without going with an extremely conservative offset.
BTW where have you been? Haven't seen you post...how's the car holding up?
Old Feb 27, 2009 | 05:31 PM
terrycs's Avatar
Yes .. camber or tire stretch would be needed. BLUESLATE has 10.5 on his car now. I'm ALWAYS around.
Old Feb 27, 2009 | 05:59 PM
beezy619's Avatar
Thanks for the advice guys. I was hoping to take what 07IMLG setup and push the envelope a bit further, but I guess its not gonna happen with our cars unless one is willing to run camber and stretch the tires.
Old Feb 27, 2009 | 06:19 PM
boss81's Avatar
I have 10.5 wide wheels and 275s in the back, and I'm good to go.
Old Feb 27, 2009 | 06:21 PM
beezy619's Avatar
Any rubbing? Do you think you could fit 285's in the rear?
Old Feb 27, 2009 | 06:22 PM
boss81's Avatar
No rubbing, I don't know about the 285s.
Old Feb 27, 2009 | 07:16 PM
beezy619's Avatar
I guess 275's the way to go....Are you rears stretched at all?
Old Feb 27, 2009 | 07:38 PM
boss81's Avatar
They don't look it, can't be sure though.
Old Feb 27, 2009 | 07:50 PM
da mayor's Avatar
i heard someone can fit a 295/30/20 tire on the rear of it
Old Feb 27, 2009 | 07:55 PM
beezy619's Avatar
WOW!!! I wonder how much camber they needed to run to make that fit? Any pics?
