Tire Emergency!
Old Mar 7, 2009 | 09:56 PM
EWG35's Avatar
Originally Posted by Israeli_G
what if i got 9.5 in the back? and does spining at a higher rpm do anything i.e. slip sensor goes off?
You should be just fine. Not sure what you mean by slip sensor, unless you mean VDC. If that's what you are referring to your fine. I would have advised 245/40 19 but if you already have them you are set. 275's on 9.5 isok. I think 9.5 to 10.5 is the suggested range.
Old Mar 8, 2009 | 03:33 AM
weeweelo's Avatar
275/35/19 S.Drive tire on 19x9.5 30 offset if your camber set -2.5 still have like 5mm stick out.
TwinTurboZ
19 Inch
Sep 26, 2015 06:11 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
philthethrilloh
Sep 9, 2015 01:25 AM
socaldavid
Sep 5, 2015 04:35 AM
