"Official" GT SPEC Strut Bar & chasis braces - Reviews, Opinions & Thoughts
Old Jun 29, 2009 | 03:32 PM
  #91
E-Ticket Ride's Avatar
Originally Posted by InTgr8r
It looks like clearance is minimal even with the OE pipes.
IDK id the FI follows the OE path exactly or not
Has anyone installed this in combination with the FI exhaust?
....any clearance issues?
I emailed GT spec a while ago about the M brace and A/M exhausts. They had no info on any exhaust (other than the oem) fitting with the M brace.
Old Jun 29, 2009 | 04:42 PM
  #92
InTgr8r's Avatar
Staff ALUMNI (retired)
...I thought about this a little more after I posted.
I get my FI tomorrow.
I thought I'd make a template of the OE exhaust before I remove it.
Then I can check it against the FI after I install it.
That M brace is critical to the floor brace working properly IMO.
Old Jul 12, 2009 | 03:14 PM
  #93
G35s-Q8's Avatar
I would like to get all of them at once, but i rather spend my cash on mods instead, so i'll be getting FSB and sway bars 1st, i'll see if i'll get the rest later.
I wonder if that M brace would fit the Invidia, but somehow i doubt that, i'll try to compare clearance between stock exhaust and the Invidia, it should arrive anytime at the end of this week or on the weekend.
Old Jul 13, 2009 | 03:07 AM
  #94
G35Robby's Avatar
Amplified Motorsports said it will. There was a g37 at the shop and he had a M brace with the Inivida exhaust. The piping is the same style.
I can double check for you bro.
Old Jul 13, 2009 | 10:50 AM
  #95
G35s-Q8's Avatar
Would be great, i don't want to spend money on something i can't even use.
Maybe i can poke people with it .
Old Jul 13, 2009 | 11:22 AM
  #96
InTgr8r's Avatar
...I'm still looking into the fit on a FI system.
I thought I read a post that someone has installed it on an FI,
but I can't find the needle in the haystack.
Old Jul 13, 2009 | 12:40 PM
  #97
G35s-Q8's Avatar
You can buy it, try it, if it worked then you lucky, if it didn't then you can try and sell it to any member here.
OR you can go to any dealer and try testing if it'll fit before buying it, that would help us a lot to decide wether to get it or not.
Old Jul 13, 2009 | 04:33 PM
  #98
Just tell Robby to check it at Lou's shop if Lou has it in stock.
Old Jul 13, 2009 | 07:27 PM
  #99
mishmosh's Avatar
From that picture, it looks like the M brace sits at least as high as the top bend in the sway bar--there shouldn't be any reason why an aftermarket exhaust wouldn't work with it.
Old Jul 13, 2009 | 08:41 PM
  #100
InTgr8r's Avatar
^ IDK
From that angle, it's hard to tell.
Old Jul 14, 2009 | 03:19 AM
  #101
That looks like a stock sway bar, but most of us have Hotchkis which are slightly fatter too. I think the Hotchkis sits a bit lower too due to the new mounts/thicker bushings, but I could be wrong. Something to keep in mind.
+1 on being hard to tell from that angle.
Old Jul 14, 2009 | 02:57 PM
  #102
InTgr8r's Avatar
here's a different angle.
In this one you can see how the OE exhaust dips down where the M brace crosses.
AFAIK most aftermarket exhaust comes straight through.
...it's definitely lower than the sway bar.
Old Jul 14, 2009 | 06:00 PM
  #103
G35Robby's Avatar
As for the sedan, we dont have any weird bends in our exhaust.
I just tried to compare my Invidia to my stock exhaust and it seems like we should be able to clear it.
Old Jul 14, 2009 | 08:41 PM
  #104
InTgr8r's Avatar
I just did the sane with my FI & took a couple of pics......
Looks OK to me too, I'll be ordering.
...worst case a small spacer under the hangar to drop it a smidge.
arrow is where M brace bolts up
Old Jul 14, 2009 | 08:52 PM
  #105
Q8y_drifter's Avatar
if the brace touches that thing will rattle like crazy! lol
