OEM 19s Rays Forged
Old Apr 24, 2009 | 02:37 PM
AlexF's Avatar
OEM 19s Rays Forged
I'm considering getting the 19x8, 33 offset, with a 245/40 tire. I remember reading that these look a bit sunken in on our sedans, especially when lowered(impul springs). What size spacers should I use to give me that 'flush with the fender' look? Also, I believe they weigh around 20 lbs? thanks in advance.
Old Apr 24, 2009 | 02:39 PM
Jeff92se's Avatar
Red Card Crew
You getting 4 fronts?
Old Apr 24, 2009 | 02:41 PM
AlexF's Avatar
Yes.
Old Apr 25, 2009 | 11:17 AM
AlterZgo's Avatar
Why not go with 4 rears and that would be flush at all 4 corners?
If you go with the 19x8 +33 fronts, I would run 10 mm spacers. That would look pretty flush even w/ lowering. This set up would be pushed out exactly 1 mm more than my 19x8.5 +30 set up with 245-40-19s:
Old Apr 25, 2009 | 01:09 PM
Wes_888's Avatar
thats a beautiful shot of your G AlterZgo
Old Apr 28, 2009 | 11:52 AM
SANTOS29's Avatar
^^werd, great shot
Old Apr 28, 2009 | 03:02 PM
aooooo's Avatar
why not just go staggered?? "i have awd" .. so what?? man up. nothing is gonna happen. this is the 2nd yr im staggered and by staggered i mean 9.0 in the fronts and 10.5 in the rears lol. if something were to happen, put your stocks on go to the dealership and say wtf =)
Old Apr 28, 2009 | 06:42 PM
2007BlueSlate's Avatar
Sorry to veer off topic but a quick question. AlterZgo, have you lowered your car at all in the picture??
Old Apr 29, 2009 | 12:55 PM
AlterZgo's Avatar
Yes - car is lowered w/ Eibach Pro-kit springs.
aooooo - Agree with you 100%. Staggered widths on AWD will cause no problems at all as long as the front and rear tires are the same height.
Old May 14, 2009 | 10:09 AM
AlexF's Avatar
I made a mistake in my initial post..the 19x8 fronts are 30 offset, 19x8.5 rears are 33 offset. I'm going with the rears all the way around. To flush out the look with the fender, do I still go with 10mm spacers? who makes good hubcentric spacers?
Old May 14, 2009 | 11:18 AM
jran76's Avatar
I would roll with the 19x8.5 +33 as is with no spacers to see what you think. The front is going to be fine. For hubcentric spacers.... Try Kics, Eibach, or Ichiba. If you are running Nissan or Infiniti wheels there is no need for hubcentric rings if you are not running spacers; they will already have the 66.1mm bore.
Old May 14, 2009 | 11:51 AM
AlexF's Avatar
Thanks. Are there any aftermarket wheels(not custom like HRE, etc.) that are hubcentric to our vehicle with a 66.1mm bore?
Old May 14, 2009 | 12:07 PM
AlexF's Avatar
Holy S**t!!
I just called parts at my local Infiniti dealership...$948 per rim!
Old May 14, 2009 | 12:13 PM
G35xQX1's Avatar
um...hell no @ the price. but it sounds typical for a "dealership" to charge that much. you can get some super sic aftermarket wheels for that kind of cash.
id suggest you look @ the private classifieds here
Old May 14, 2009 | 12:50 PM
jran76's Avatar
Most aftermarket wheels that fit our cars have a 73.1mm center bore (and would require hubcentric rings).
