BEST recommendation for warped rotors
Old May 11, 2009 | 11:13 PM
guitarplayax's Avatar
Hey guys,
SO I have 11k miles on my 08 g35x and the rotors are warped as ish. Now I don't really want to go to the dealer and pay to have the rotors cut when it's only a temporary fix. I'm running the stock 17s and I really can't afford to upgrade to a BBK and buy new wheels/tires. What would be my BEST option here? I really don't want this to happen again. Post links if possible thanks.
Old May 11, 2009 | 11:26 PM
E-Ticket Ride's Avatar
If there's enough material left (and there should be if this is the first time), take it somewhere else and have the rotors turned. You don't necessarily have to do it at the dealership (and get raped in the process).
Old May 11, 2009 | 11:27 PM
AesonVirus's Avatar
You're not alone on this one.
Mine warped at about 25K and the dealer turned them for free.
The problem came back (you can't turn a warped rotor without it coming back) at about 30K. Dealer replaced them under warranty.
I'm not at 38K and although they are not warped, I can feel they're not perfect anymore.
WTF with these crap rotors.
I'm in the same boat... I'll need good aftermarkets. I'm done with these useless OEMs.
Old May 12, 2009 | 03:18 AM
IvoryPearl07G's Avatar
power slot rotors-hawk pads-stainless steel lines should hook you up nicely!
should run around 600-700 dollars
Old May 12, 2009 | 08:58 AM
iceberG's Avatar
^Do you know if they have Powerslot rotors for the Sport? I'm in the same situation as the OP but, having a difficult time finding rotors that fit the 07 Sport that is not a big brake kit. Rumor has it that the G37 non-sport should fit but, I have no proof.
Old May 12, 2009 | 07:49 PM
i dont think they do, but i havent looked in a while.
personally, i was gonna get the G37 Big brake upgrade from riverside infiniti and then get some rotors and lines to go with it
Old May 16, 2009 | 09:01 PM
pwebb's Avatar
at 11k miles, you can probably swing a warranty resurface at the dealer.
Old May 16, 2009 | 09:23 PM
gary c's Avatar
Warped Rotors....NBFD!
Warped rotors are caused by two issues, poor quality forging and some jack azz installing your wheels with a impact gun or both! You can get Infiniti to turn your rotors under warranty. That's not a quick fix, they might last for another 30K+ miles. If anyone removes your wheels make sure they're put back on with a torq wrench set on 85. I had this issue with my last Z and it still had the same turned rotors on it at 125K miles when I sold it!
Gary
Old May 16, 2009 | 09:40 PM
It can also be a result of repeated high speed braking, over a period of time of course
Old May 16, 2009 | 11:23 PM
stardust's Avatar
It can also be caused by crappy OE brake PADS
Old May 17, 2009 | 01:05 AM
Ball.Saxbury's Avatar
Look into some EBC rotors - they're not very expensive and are excellent performance rotors.
Old May 17, 2009 | 02:08 AM
jimk's Avatar
i have the 08 sport with 13" rotors. are they the same as the g37 big brake you referred to??
Old May 17, 2009 | 03:28 AM
No, the G37 Akebono's use a 14" rotor in front.
Old May 17, 2009 | 08:16 AM
Texasscout's Avatar
Are they TRUELY warped? In about 80% of the cases, they are not. What happens is when you get them REAL hot, and you sit still with the brakes applied, you get pad material "transfer" to the rotor. They are not warped, just got pad compound on them. It's a simple thing to take them off and sand them down or go to a reputable auto parts store and have them shave a couple of thousandths off of them.
Read more here: http://www.stoptech.com/tech_info/wp...rakedisk.shtml
One way to fix it: http://www.stoptech.com/tech_info/wp_padremoval.shtml
Old May 17, 2009 | 07:34 PM
pwebb's Avatar
using an impact to install the wheels is a completely acceptable way of doing things. I have put on countless rims on this way, and havent had any customers come back with warpage issues. the ones that do come in with pulsation issues show evidence that the customers put their braking system to good use
heat warps rotors.
they make a tool called a torque stick. this puts a cap on the amount of twist that the impact can muster. this also keeps the torque quite even across each lug, without the use of a torque wrench.
heat is the enemy.
