Available tires for the oem 18's
Old May 28, 2009 | 04:51 PM
Scooby24's Avatar
Originally Posted by Austin713
shows you how much i have looked into it.... do a search, i bet you will come up with something.
do they allow strut tower bars or any kind of bracing? i hear G-spec has a pretty good tower bar.
Nope. I haven't looked into it in awhile, but my last car was automatically thrown into SM because I had a chassis brace and strut towers. SM is guaranteed failure.
Old May 29, 2009 | 08:49 AM
snowcrossmxz's Avatar
Originally Posted by Scooby24
To stay in D stock I'd have to have wheels with the same width and offset which is going to be hard to find without getting another set of factory wheels. Just not worth the added expense IMO.
The guys on the local scca boards are telling me my car's problem with pushing could be fixed with a wider front tire so maybe the 245 is the way to go.
I could always say in-line front to rear ratio and go 225/45 and 245/40. Those are available sizes for the tires I want but the overall rolling diameter will be off 3.6% from factory. That's going to throw off the speedo enough to notice as well as change the mechanical advantage...not sure whether for the better or worse.
ur drive tires will be smaller, which means ull have a lower final drive ratio.
IE faster excel, and lower top speed. not a hudge difference, but maybe enuf to shave off a few tenths
also a smaller side wall will be less prone to rolling
good luck beating ur buddy
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
bTanz
Oct 15, 2015 02:31 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
mushu
Jul 15, 2015 03:55 PM
