braking squeaks when coming to a stop
Old Jun 3, 2009 | 06:44 PM
ckp's Avatar
ckp
ok guys...so when I come to a stop in my car the breaks start having pretty loud squeaks at 10mph and below. what is causing this? will they cover this under warranty? what do you guys think? its annoying as hell!
Old Jun 3, 2009 | 06:48 PM
Borna's Avatar
They probably just need to resurface the rotors and change the pads.
It happens over time so just have them check it out.
Old Jun 3, 2009 | 06:53 PM
ckp's Avatar
ckp
well i had the pads checked and the guy said there is plenty of life left on the pads. so i know its not the pads....maybe the rotors need to be resurfaced, which i assume they will charge me for, not under warranty?
Old Jun 3, 2009 | 06:59 PM
CalsonicVQ's Avatar
ITB09-009
FRONT BRAKE SQUEAL / SQUEAK NOISE
APPLIED VEHICLES: 2007 - 2008 G35 Sedan (V36) Sport Models ONLY
2008 - 2009 G37 Coupe (CV36) Non-Sport Models ONLY
APPLIED VIN: Vehicles built before JNKCV6(****)M604451
APPLIED DATE: Vehicles built before November 7, 2008
IF YOU CONFIRM
Squeal/Squeak noise from front brakes.
ACTION
Replace the front brake pads and front brake hardware kit with the parts listed in the Parts Information section
of this bulletin.
Refer to the appropriate section of the Electronic Service Manual for removal and installation procedure.
Road test the vehicle to confirm the issue is resolved.
PARTS INFORMATION
DESCRIPTION PART # QUANTITY
Pad Kit – Front Disc brake D1060-JK00B 1
Hardware Kit – Front Disc Brake D1080-JK00B 1
Old Jun 3, 2009 | 07:05 PM
ckp's Avatar
ckp
So that means its under warranty? do i just go to the dealer and tell them its should be covered under ITB09-009? or what?
Originally Posted by CalsonicVQ
ITB09-009
IF YOU CONFIRM
ACTION
of this bulletin.
PARTS INFORMATION
Old Jun 4, 2009 | 08:21 AM
snowcrossmxz's Avatar
does you vin fit that ITB, if it does then yes.
MAKE SURE you tell them about this ITB when u bring it in
Old Jun 4, 2009 | 10:56 AM
pwebb's Avatar
its the dealers job to make sure the bulletin applies...
Old Jun 4, 2009 | 11:03 AM
correct,
but its a job that they don't do very well
my car went it because the door weather strip came off.
they put it back in, and it came out again 3 weeks later. so they fixed it again.
and now the weather is heating up again and its starting to pull loose again.
they DID NOT apply the ITB to fix the problem (there is one on it)
so when i go back for the 3rd time. i am going to print it out and say do this to ALL the doors.
even tho it is a dealer with infiniti behind them, in reality, they are still just a car shop with a nice logo on the front door.
so just print out the itb and say check this on my car.
tiguy99
Mar 1, 2016 11:42 AM
wuppiedog
Aug 7, 2015 11:16 AM
sahizzle110
Jul 29, 2015 11:36 AM
ddietz97
Jul 26, 2015 06:16 PM
mushu
Jul 15, 2015 03:55 PM
