Who here has spacers and has resulted in wheel vibration?
Old Jun 10, 2009 | 11:18 PM
Wes_888's Avatar
As the title suggest, im just interested to know the ratio of wheel vibration associated with spacers.
Thanks for the input.
Old Jun 11, 2009 | 08:13 PM
Wes_888's Avatar
anyone? :P
Old Jun 11, 2009 | 11:37 PM
mishmosh's Avatar
mild vibration, but it's there at about 70mph. Feels as though tires are unbalanced. Not there without the spacers and there with two different setups. Next time I do a rim change, I will remount the spacers being carefull to gradually tighten the nuts sequentially.
Old Jun 11, 2009 | 11:40 PM
Wes_888's Avatar
Thanks Mishmosh.
Let us know if that works for ya.
Old Jun 12, 2009 | 01:01 AM
cmo23's Avatar
i have the 15mm Ichibas in the rear and i get a vibration between 45-60 mph. only noticeable with the windows up and radio down... but still. i dont want to install on the front bc i dont want more vibration and definitely dont want to feel it in the steering wheel.
Old Jun 12, 2009 | 01:10 AM
Kris79's Avatar
battle froggy
loooks like there is a common factor here.
Old Jun 12, 2009 | 08:01 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
I have a mild vib at highway speeds >120km/h.
I have Ichiba V2 & I think I found the problem.
...& a possible solution.
I need to take a few pics & do a test to confirm.
Note:
My issue applies to OE wheels only.
Old Jun 12, 2009 | 09:14 AM
Wes_888's Avatar
Indeed.
Thanks for the replies guys. Keep it coming.
Old Jun 12, 2009 | 09:24 AM
GreenGoblin's Avatar
The goblin resurrection
are you guys torquing them to the factory spec's in the star pattern? I never got a vib from any of the hubcentric spacers that I have used.
Old Jun 12, 2009 | 10:57 AM
MoJ's Avatar
MoJ
Might I suggest having everyone add some details to their reply?
-type of spacer (integrated lugs or traditional)
-thickness
-brand
-hubcentric?
Old Jun 12, 2009 | 12:21 PM
cmo23's Avatar
1) traditional i suppose
2) 15mm (rear only)
3) ichiba v2
4) dont know what hubcentric means- but i assume you guys will be able to tell me that based on the info above. i obviously had them installed by a shop.
btw- im also using these with stock journey 17" wheels- so i am looking fwd to InTgr8r's test
Old Jun 12, 2009 | 01:26 PM
Cabad85's Avatar
+10000!!
You may get vibration if not torqued to spec in the proper pattern even w/o spacers.
Old Jun 12, 2009 | 10:27 PM
Wes_888's Avatar
Originally Posted by Cabad85
+10000!!
Is this common knowleadge among auto shops/dealerships?
to torque the wheels in a star pattern? cuz I never knew this.
Thanks for sharing.
Old Jun 13, 2009 | 08:18 AM
InTgr8r's Avatar
Yes, it's SOP
Old Jun 13, 2009 | 08:37 AM
GEE35FX's Avatar
Thanks for sharing.
You are darn right it is common knowledge in shops and among most car DIY'ers.
As a matter of fact it is law that shops must torque your wheels to the proper spec.
Here Wes, read this about torquing sequences: http://www.tirerack.com/wheels/tech/techpage.jsp?techid=107
