stainless steel brake lines?
Old Jun 16, 2009 | 12:54 PM
Thrillryder23's Avatar
So I'm thinking of putting on stainless steel brake lines from stillen but I'm not too sure about the real results I'll get opposed to the claimed results.
I've read that it will make the brake pedal much more sensitive (which I want). Are there any other benefits? Has anyone else used Stillen's steel brake lines on the g35 (I have the '08 xS) and if so what kind of results did you see?
Thanks
Old Jun 17, 2009 | 07:59 AM
snowcrossmxz's Avatar
r u using the stock brakes?
usually people who upgrade their lines also upgrade the binders too.
so it might be hard to find some one who can give u results of just a brake line upgrade.
Old Jun 17, 2009 | 08:50 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
On the street, you will hardly notice any difference at all.
Been there, done that, won't bother again until the OE lines need to be replaced.
Old Jun 30, 2009 | 04:35 AM
ampsucker's Avatar
i did it on a 240sx. made a huge difference on that car.
can't imagine it would do a lot on a G, though. our brakes have pretty good pedal feel with the stock set up in my opinion. the things i don't like about the G brakes probably couldn't be fixed with new lines.
to me, the main motivation to go with ss lines is to eliminate the flexing of the rubber components in most oem setups and get a more direct relationship between the pressure you push on the pedal with and the amount of brake pad travel at the wheel. you'll have slightly more modulation ability, but so much of that is damped already with vdc, abs and preload gadgetry that i doubt you'll see much difference except at the limits.
amp
jilljann1
Jul 21, 2020 08:12 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
boostelevator
Brakes
Oct 5, 2015 08:56 AM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
bananax
Wheels & Tires CDN
Sep 10, 2015 06:14 PM
