Which offsets
Old Jun 16, 2009 | 10:18 PM
ketchupfreak's Avatar
Which offsets
http://www.5zigenusa.com/english/pro...ne/sc3000.html
Which offsets will I need for a staggered 8.5/9.5 setup on Eibach prokits?
Old Jun 17, 2009 | 03:04 AM
weeweelo's Avatar
You need for the front 8.5 +38 but better put 10mm space after and the Rear 9.5 +38 will be perfect.
Old Jun 17, 2009 | 04:28 AM
beezy619's Avatar
Why not +25 in front? "heyitsalex" put +17 in front and said he still had room.
Old Jun 17, 2009 | 08:53 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
check out the data base sticky at the top.
....tons of offset info in there.
Old Jun 17, 2009 | 12:29 PM
weeweelo's Avatar
+25 is ok but alittle too much look like the front stick out more than the rear.(when is on the car)
Old Jun 17, 2009 | 12:43 PM
CalsonicVQ's Avatar
Distance from hub mounting surface to outer edge of rim:
8.5in (+25mm offset) = 82.95mm
9.5in (+38mm offset) = 82.65mm
I think you'll be happy with aforementioned offsets.
Old Jun 17, 2009 | 01:14 PM
Thanks. Will I need to run spacers or roll fenders at all?
Old Jun 17, 2009 | 05:20 PM
Borna's Avatar
Yeah 8.5 +25 and 9.5 +38 will give you a very nice fit.
You won't need spacers and the fenders are rolled from the factory on our cars, so nothing to worry about.
You'll have to run a bit of negative camber if you're lowered, but nothing extreme at all. Just make sure the toe is in spec when getting an alignment.
Old Jun 18, 2009 | 05:11 PM
supracrazy's Avatar
why not just run 9.5+38 all around?
Old Jul 21, 2009 | 01:03 AM
jimmyjones's Avatar
hey guys i'm in the market for new wheels 19x8.5 and 19x9.5 F/R but am unsure of the offsets . i've looked at the suspension document on the forum and think i can go with a +20/35 F/R offset...only thing i'm worried about is the fronts sticking out past the fender. i plan on going with a subtle drop (tein h-tech) and want the wheels/tires to be flush with the fenders but as little camber as possible, is +20/35 F/R do-able?
thanks in advance!!!
Old Jul 21, 2009 | 04:30 AM
Borna's Avatar
Go for 8.5 +25 and 9.5 +35 like posted in this thread.
Those offsets would sit flush without having to run much camber.
8.5 +20 would need around 1.8* of camber while +25 would only be around 1.3-1.4
+20 is definitely do able but if you go with 8.5 +20 I'd recommend 9.5 +30 just so they sit as flush as each other. If the rear is more aggressive its good but you don't want the front wheels to be more aggressive cause it'll just look weird.
Old Jul 21, 2009 | 12:31 PM
jimmyjones's Avatar
thanks for the info Borna, it is much appreciated! i'm going to go with 8.5 +25 and 9.5 +35 F/R. I don't want to run much camber so that should work out really well.
thanks again!!
Old Jul 21, 2009 | 07:19 PM
Borna's Avatar
No problem, post up pics when you get them.
seagrasser
May 3, 2022 09:43 AM
Picture Share
Feb 4, 2018 12:41 PM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
TurTLe*
Sep 29, 2015 01:43 PM
