Will these rims fit on my car?
Old Jul 24, 2009 | 01:41 PM
denishot's Avatar
Will wheels this size fit on my car?
20x8.5 Front 20x10 Rear offsets 25-30
Maybe I'll dial in some negative camber if I have to?
Thanks
Old Jul 24, 2009 | 02:17 PM
beezy619's Avatar
What tire sizes are you planning on running? I'm sure +25 fronts will fit fine. +30 rears should fit with a little camber, but not sure on what tire size to run.
Old Jul 24, 2009 | 02:25 PM
denishot's Avatar
245/35/20 & 285/30/20
Old Jul 24, 2009 | 02:49 PM
4DGS's Avatar
I am pretty sure other guys have had problems running 285s.
You're going to be rolling your fenders for sure.
Old Jul 24, 2009 | 02:51 PM
beezy619's Avatar
IIRC denishot has a 2nd gen sedan and our cars come with rolled fenders in the rear.
Old Jul 24, 2009 | 02:59 PM
4DGS's Avatar
So a 10 will clear with no rubbing???
Old Jul 24, 2009 | 03:13 PM
denishot's Avatar
yeah i have a 2nd gen
my friend has 10.5s in the rear but he has higher offsets and he doesn't rub, i was just wondering if i'd be able to run offsets that low without it sticking out so much
beezy619's Avatar
Ok just to put this out there....I'm no way a offset guru. I'm still in the learning stages as well. I've just been doing research on a similar setup I want to run and this is what I've found. Check this thread out: https://g35driver.com/forums/media-s...five-axis.html
He's running 19x10.5 +33 in the rear and running 275/30/19 tires. Fitment looks good, so I'm guessing 20x10 +30 wouldn't be too hard, but lets let someone with more experience chime in.
Old Jul 24, 2009 | 03:19 PM
denishot's Avatar
heyitsalex is running crazy offsets too, just wanted to be sure before i pursue the rims
Old Jul 24, 2009 | 03:49 PM
CalsonicVQ's Avatar
I have 20x8.5 (+25mm) and 20x10.0 (+45mm) rims and 245/35 and 285/30 Falken FK452 tires. You'll have no problems with the front...the rears you definitely need negative camber if you want to run 25-30mm offset.
Old Jul 24, 2009 | 08:00 PM
beezy619's Avatar
Bump for more input.
Old Jul 25, 2009 | 01:43 AM
Borna's Avatar
Those will fit no problem with around 1.8* of camber back and front.
I'd recommend you go with 275/30/20 out back though cause the 285's will be a very tight fit, plus the extra camber you'd need to run 285's would mean less contact patch anyways.
Old Jul 25, 2009 | 01:48 AM
beezy619's Avatar
What about 10.5 +30 in the rear? Will 275/30/20 still be ok?
Old Jul 25, 2009 | 02:47 AM
denishot's Avatar
Borna, i'm buying a set of rims with tires on already. thanks for the help guys, i'll post pics once i get them
Old Jul 26, 2009 | 01:15 AM
denishot's Avatar
You should be fine beezy, if anything dial in some camber
What are you looking to get if you don't mind me asking?
