245 Front Tires
Old Aug 28, 2009 | 04:38 AM
G35_RJ's Avatar
on my '06 6MT sport I ran Yokohama Avid 245/45R18 on all corners, the car stuck like glue to the road...
Old Aug 28, 2009 | 03:53 PM
joesmithf1's Avatar
you guys with the 245 fronts, is there inner rubbing issue? Do you need spacers? I called TireRack and one of the CS told me to be aware of inner rubbing.
Old Aug 28, 2009 | 05:00 PM
Texasscout's Avatar
Nope
Old Sep 1, 2009 | 08:31 PM
jpr's Avatar
jpr
No rubbing at all for me either. feels stock but with less understeer.
Jpr
Old Sep 4, 2009 | 04:08 PM
MoJ's Avatar
MoJ
Originally Posted by CalsonicVQ
Original factory spec is not always optimized for performance. There's always a trade off between performance, comfort, price, etc... Original factory spec is what Nissan feels is the right balance for the marketplace. Oftentimes, it's not the right balance for us enthusiasts.
Nice point. Manufacturers often position the car to have slight understeer which is considered safer. In theory, moving to a wider tire up front will reduce understeer.
Old Sep 4, 2009 | 08:50 PM
joesmithf1's Avatar
thank you guys. Just bought the 245 Kumho LX Platinum and installed them on the front. They look awesome!!! Perfect fit and aligned with the wheels perfectly! No rubbing at now. Now i am just gonna wait and see how well these Kumho are.
Old Sep 22, 2009 | 05:48 PM
ultraman1017's Avatar
you have 18" wheels? can you tell me ur original and new sizes (front and rear). many thx
Old Sep 22, 2009 | 06:10 PM
nghiars's Avatar
we got guys running 9.5 in rims in the front and sometime even bigger without rubbing issues.. you're only going 20mm larger on your stock whell... you have plenty of room..
Use this link to compare different tire sizes that will work: http://www.1010tires.com/TireSizeCalculator.asp
Old Sep 23, 2009 | 01:20 AM
joesmithf1's Avatar
i have the 19" from the G37 Sport Coupe.
Orignal sizes are:
Front 19x8.5 - 225/45R19
Rear 19x9 - 245/40R19
New sizes:
Front and rear both are 245/40R19
Hope this helps.
Old Sep 23, 2009 | 04:03 AM
h2mann's Avatar
I am running with 19" wheels on my g, with h&r springs
245/40 up front on 9.5" wheels
255/40 rear on 10"
no rubbing issues, car does grip better on corners but at slow turns does feel a bit "heavier" if thats the word. Just more rubber on the road.
Only drawback is Im on my 2nd set of tires due to my camber being a little off so I had some inside tire wear.
Old Sep 24, 2009 | 10:09 PM
Orignal sizes are:
New sizes:
Hope this helps.
thx man, how do you like ur kuhmo tires? also any adjustment you have to do get to those 19" rims and tires work correctly? and is it true that all 19x8.5 & 19x9 rims will fit our cars (08 G35S)?
Old Sep 24, 2009 | 10:51 PM
joesmithf1's Avatar
i love the kuhmo, very quiet compare to the OEM. The best part about them are the tread life, 60,000 miles. There are a lot of good review for them. No. You do not have to do any adjustment; they fit perfectly if you get the 245. However, just keep in mind the G37 Coupe Sport wheels are staggered, so you can't put the back rims on the front.
The G37 Coupe sport wheels will definitely fit our cars, BUT if you get some other brand, you'll need to determine the offsets and bolt patterns, etc. I am not an expert on wheels, so maybe some other members can give you a better advise.
Old Sep 26, 2009 | 11:16 AM
Texasscout's Avatar
Are the Kuhmo's some of the tires that Obama just put a 100% tarriff on? Are they from China?
Old Sep 27, 2009 | 01:19 AM
255/40 rear on 10"
do you think those sizes will work for 08 G35S sedan? thx!
front: 19" x 9" - 37 - 5/114.3
rear: 19" x 10" - 37 - 5/114.3
Old Sep 27, 2009 | 01:22 AM
  #30
I am waiting for my OEM tries wear out and get those...
