View Poll Results: Does your GTSPEC strut bar rub?
No
40.00%
Yes, on the hood liner
50.00%
Yes, on the engine cover
10.00%
Voters: 20. You may not vote on this poll
Old Sep 1, 2009 | 06:56 PM
bat6wc's Avatar
Simple Poll: Does your GTSPEC front upper strut bar rub and if so, on the engine cover or hood liner?
Old Sep 1, 2009 | 07:12 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Yes, but it's very minor.
I really don't care if there are a few scratches on it,
I want the bracing.
On mine it rubs both.
I have it so it barely touches the hood, but it has marked the engine cover slightly as well.
Old Sep 1, 2009 | 07:31 PM
AesonVirus's Avatar
I can't vote. I don't have one... yet.
Old Sep 1, 2009 | 09:21 PM
Defratos's Avatar
You're Despicable
I don't have any of the braces either (yet) but how does it rub? does it touch the ground?
Old Sep 1, 2009 | 09:24 PM
Greekboy115's Avatar
I don't have one yet either but would love some more input as this wll most likely be my next mod.
Old Sep 1, 2009 | 09:39 PM
AesonVirus's Avatar
Where's the cheapest place to get one?.... and don't say HPAutoworks.
If they're the cheapest, I'll settle for second cheapest.
Old Sep 1, 2009 | 10:06 PM
InTgr8r's Avatar
If you call Riverside they will deal.
Old Sep 1, 2009 | 10:08 PM
InTgr8r's Avatar
Under braces are no problem (well maybe if you're in the weeds )
With the STB, there is just so very little clearance across the top of the engine,
it's almost impossible not to rub a bit.
Old Sep 1, 2009 | 10:15 PM
patman530's Avatar
i have a 05 coupe, and mine rubs on the liner, it sucks because there is residue left on the bar from the rubbing
Old Sep 2, 2009 | 12:57 AM
mw08G35S's Avatar
@ like 60% height it doesn't rub,
there's a small clearance. if you want to adjust it, just put a drop of wax on the bar and close it, repeat until it doesn't touch the hood liner.
I got mine to fit without touching the engine or the hood liner.
Old Sep 2, 2009 | 01:52 AM
G35xQX1's Avatar
Mine rubs on my hood liner...no biggie though. As InTgr8r wrote, I'd much rather have the extra bracing
Old Sep 2, 2009 | 02:23 AM
I had no idea there was so many rubbing issues with the brace, however I can't say that it has changed my mind with wanting one at all. Everything sounds very minor.
Old Sep 2, 2009 | 02:24 AM
That is a really good tip, I am going to have to use that when I end up with my brace. Thank you mw08G35S
Old Sep 2, 2009 | 08:28 AM
AesonVirus's Avatar
There's also a DIY on lowering the engine cover a tad.
http://myg37.com/forums/brakes-suspe...clearance.html
Old Sep 2, 2009 | 10:12 PM
bat6wc's Avatar
Ill be installing mine tomorrow afternoon.
im curious to see pics of the rubbing damage after time, both on the car and liner/engine cover. I am pretty sure I can deal with the rubbing on the liner only if the wear/tear is confined to the liner. I dont want any finish damage on my newly powdercoated bar.
