g37 coupes + 15mm spacers
Old Sep 7, 2009 | 08:01 PM
cmo23's Avatar
alright guys- ive tried asking this question before on some of the "check out my new g37 wheels" threads- but have never gotten a response. so im starting my own thread:
will i have fitment issues with the g37 coupe rims while using the ichiba 15mm spacers? and if so, do i have to reinstall my stock shorter bolts or can i simply just remove the 15mm spacer plate and keep the longer bolts on with the g37 wheels?
i know that question could have been worded better- i obviously do not understand offsets and how they work. but thanks in advance for your patience.
g37 wheel specs:
front 19x8.5 +43 offset
rear 19x9 +45 offset
Old Sep 7, 2009 | 08:23 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
The V2s don't use a longer bolt.
The whole idea of the V2 is to retain OE hub bolts
Old Sep 7, 2009 | 09:18 PM
cmo23's Avatar
then i guess that means i have the v1 ichibas because the mechanic gave me back my OEM bolts after they installed the spacers.
Old Sep 7, 2009 | 09:33 PM
InTgr8r's Avatar
OK...
Then yes, if you want to remove the spacers you will need to change the studs back to OE length.
....unless you go to open end lug nuts.
Old Sep 7, 2009 | 09:40 PM
cmo23's Avatar
ok- thanks InTgr8r for the info.
however that doesnt really answer my initial question. will i have fitment issues if i use the spacers with the g37s? to be more precise- will my wheels be sticking out too much or will have i have rubbing issues?
Old Sep 7, 2009 | 09:53 PM
aBLUEg35's Avatar
i really doubt it. as far as i know people are running 25mm spacers without problems
Old Sep 7, 2009 | 10:06 PM
InTgr8r's Avatar
^ 25mm on G37S coupe wheels?
IDTS
Old Sep 7, 2009 | 10:11 PM
aBLUEg35's Avatar
yup....lol
Old Sep 8, 2009 | 02:11 AM
E-Ticket Ride's Avatar
I don't think the rear needs one at all, maybe only the front:
Old Sep 8, 2009 | 10:41 AM
InTgr8r's Avatar
^ there ya go...
Old Sep 8, 2009 | 12:23 PM
Greekboy115's Avatar
Looks pretty perfect to me.
Old Sep 8, 2009 | 02:01 PM
The fronts "could" use a spacer, but remember that the farther out the wheels stick, the more chance you'll get for rock chips on the doors, fenders, etc. You can see in the pic that the fender/mudguard catchs almost all the rocks that would fly up and cause damage
Old Sep 9, 2009 | 02:10 AM
ericson112's Avatar
I'm dropped on h&r springs and have 15mm spacer in the front and 20mm in the rear...absolutely no rub issues at all
Old Sep 9, 2009 | 11:24 AM
cmo23's Avatar
interesting Ericson112- your wheels sit identically as E-tickets except you have spacers. so maybe its the springs? i see that you are on H&R...
E-ticket- what springs are you using?
Old Sep 9, 2009 | 11:29 AM
InTgr8r's Avatar
He has COs & is not dropped as much.
If you look closely, ericson's are definitely further out.
