Rear braces, or upgraded sway bars?
Old Sep 8, 2009 | 05:14 PM
soundmike's Avatar
Guys (and gals),
If you were to choose between the M-brace and rear tie brace, or the Hotchkis sway bar, which would you get first?
Better yet, which one would have the most noticeable effect? I've read the rear two braces act almost like a stiffer sway bar but only read that from the manufacturer.
Thanks!
Old Sep 8, 2009 | 05:44 PM
E-Ticket Ride's Avatar
Sways first for sure.
Old Sep 8, 2009 | 07:13 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
^WHS
Absolutely no contest.
..JMO, but I prefer the Stillen
Old Sep 8, 2009 | 07:30 PM
RBull's Avatar
Rated M
^whs
I was happy with the Stillens I had on the '04.
Old Sep 9, 2009 | 04:04 PM
Q8y_drifter's Avatar
wtf is whs?
Hotchkis for me. Stillen is not adjustable is it?
Old Sep 9, 2009 | 04:14 PM
InTgr8r's Avatar
Originally Posted by Q8y_drifter
wtf is whs?
What He Said
&Yes Stillen are adjustable (rear)
Neither are front adj.
That's why I stayed away from Hotchkis , their front is too stiff & w/o adj.
Increasing front stiffness more than rear = more understeer
Old Sep 9, 2009 | 04:26 PM
Hmm i don't know. On medium setting the Hotchkis sways feel very neutral, maybe a hint of understeer but definitely much less than stock. I have mine at the stiffest setting and I get slight oversteer which is great if you wanna drift.
Old Sep 9, 2009 | 04:35 PM
Defratos's Avatar
You're Despicable
Humm, dude how does the car feel with the sways set at the stiffest setting? because mine is on the lightest setting, but I wanted to push it up to medium, would you suggest just going all the way to the stiffest
Old Sep 9, 2009 | 04:57 PM
No, not until you get the JIC's on.
I'm on med right now, and I haven't tried full stiff yet.
Old Sep 9, 2009 | 05:03 PM
Foques's Avatar
I have stillen sways. best investment.. though, car still feels not as stiff as i'd like it to be
Old Sep 9, 2009 | 05:21 PM
RBull's Avatar
Rated M
wtf is whs?
LOL!
Both front and rear were adjustable with Stillens on my '04.
Old Sep 9, 2009 | 05:24 PM
dofu's Avatar
20 Year Member
Too bad sway bars don't really stiffen up the chassis... it only helps eliminate a bit of roll when you turn.
Old Sep 9, 2009 | 06:57 PM
If your tires are good (not worn out or anything) then no problem. Just take care not to slide out or enter a turn too fast cause it's pretty easy to drift lol
Old Sep 9, 2009 | 08:23 PM
InTgr8r's Avatar
Originally Posted by RBull
LOL!
That's one thing that was a little disappointing about the 2nd gen suspension redesign.
There isn't room for the front sways to have adjustment. (same for all)
Old Sep 9, 2009 | 09:22 PM
Defratos's Avatar
You're Despicable
lol ok I think I'll go for the middle Setting first, because my car slides like crazy with esp on and with good thread on my tires lol. Just yesterday it did a nice little drift in 2nd gear while going pretty slow lol I love it, but I don't want it to be too unpredictable so I think I'll try the middle setting when fitting the JICs and then see how that settles
