2007 G35 Brake Noise
Old Oct 2, 2009 | 04:31 PM
groundzero's Avatar
I have a 2007 G35s Sedan, the front breaks have been squeeking the dealer says that it is just break dust but I have had them cleaned and right after I drive out of the infiniti dealer the same noise appears is anyone having similar problems?
Old Oct 2, 2009 | 05:46 PM
bfspider's Avatar
I have the same noise. Also, the dealer says it is brake dust. The noise goes away after I wash the car for about a week. It comes back there after. I'm due for some new pads. So, hopefully I can find some pads that doesn't make the brake dust noise.
Old Oct 3, 2009 | 10:35 AM
G-Driver's Avatar
My brake squeaks a lot too. Watch out for what kind of pads you put on your stock rotors because they warp easily. I had to resurface mine twice and I do not drive my car hard. Next time I'm due for new pads I will most likely switch to new rotors and pad to avoid any more complications.
Old Oct 3, 2009 | 10:54 AM
dghboybigboy's Avatar
I'm thinking about changing my pads to Hawk Performance, their awesome pads and they don't scratch the hell out of the rotors like the material in the stock pads, they're only like $60 for all 4 I think.
Old Oct 4, 2009 | 09:18 AM
johnnyzee's Avatar
Not sure the problem exactly but there is a TSB for this:
ITB09-009
2007-2008 G35 SEDAN, 2008-2009 G37 COUPE; FRONT BRAKE SQUEAL / SQUEAK NOISE
Squeal/Squeak noise from front brakes.
or this one:
ITB00-024e
-REVISED-
ALL INFINITI MODELS; BRAKE NOISE/JUDDER/PEDAL FEEL DIAGNOSIS AND REPAIR
go to
www.inifnitihelp.com to access these TSBs
Old Oct 15, 2009 | 11:57 AM
gck's Avatar
gck
just take the rim out and put some wheel cleaner onto the calipers and get a high pressure hose and clean it ..just water though you will see like little rocks fall out..after that you will be good...yes i tried it and no more break squeaking!..also theres like a hole on the middle of the caliper like on the top part make sure u apply a lot of water there. thats where it most gets dirty
Old Apr 9, 2010 | 08:39 AM
yungsurr's Avatar
anyone know where to get good brake pads and rotors for a good price i have a 2007 g35x
Old Apr 9, 2010 | 08:46 AM
pianofrk4's Avatar
I also have a 2007 G35x and I just bought a set of EBC 3GD sport slotted/dimpled rotors and Bendix CT-3 ceramic pads for all 4 wheels... Got them for about $550 at autopartswarehouse.com. I will be installing them myself next weekend. I will let you know how it all goes... (will be my first time).
Old Apr 9, 2010 | 09:05 AM
yungsurr's Avatar
all right thanks man send me a message are you in the Massachusetts area?
Old Apr 9, 2010 | 09:11 AM
pianofrk4's Avatar
i am in MA ("boston area").
rezendvous420
May 31, 2020 01:26 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
