Why are my inside front tires bald? *Pics*
ENVautoDetailing.com
-GP-
Once your car is dropped you pretty much max out the amount of adjustments you can make to your front toe. I'm dropped on Stance Gr+ coils and the inside of my front tires are worn pretty badly. I had them aligned 10 days after my drop, and the tires are fairly new. Is there a way to fix front toe on a dropped coupe?
yeah thats why when you lower your car you have to get a rear camber kit cause the back is only so much adjustable
-GP-
-GP-
maybe I need to visit a different alignment shop and have then recheck the specs on the front wheels.
Rear camber is non adjustable at all. You'd want a rear toe and camber kit.
My tires looked just like yours after being lowered on Eibach springs. The front camber could not be brought back into spec without new SPC upper control arms.
Well you can get away with - 3 Degree's and be perfectly fine but that's track standards I believe. For street you want 0 if you can like InTgr8r, or it could also be the inflation of the tires as well or your just taking corners WAY to hard =\
Hi guys, appreciate the feedback. My tires were a bit under inflated for like a month just noticed it 2 days ago (they were at 30psi when warm) so around 27-28psi when cold, I think that would explain the excessive wear. Anyway I've inflated them to the correct pressure and I'll be getting an alignment soon, thanks for the help
My fronts are like that as well, and i'm at stock height. I doubt pressure has anything to do with it. If it's a camber issue, adjusting the pressure won't take care of the "angle" the tire is touching the road.
p.s. I check mine once a week and keep it at a constant 35-36psi.
