Installed the Akebono brakes - finally
Old Oct 28, 2009 | 10:08 PM
  #46
E-Ticket Ride's Avatar
Ian,
How bad/not bad was shimming the pads on the calipers?
That's the only thing that worries me about installing these.
Old Oct 28, 2009 | 10:17 PM
  #47
TbagzG35's Avatar
they bolt up or have to mod
Old Oct 28, 2009 | 10:30 PM
  #48
If you have an 04 like in your sig, you need the caliper adapter brackets. They're not a direct bolt on for you, but are for 2nd gens.
Old Oct 29, 2009 | 12:08 AM
  #49
InTgr8r's Avatar
Staff ALUMNI (retired)
Originally Posted by E-Ticket Ride
Ian,
I didn't use them.
I have the HPS pads & they fit nicely w/o the shims.
I just lubed the backs & dropped them in.
They seem to be fine so far... no squeeling at all.
Old Oct 29, 2009 | 03:50 AM
  #50
I had Hawks on the Mustang and could not get themto quiet down. They promptly ended up in the trash lol
Old Oct 29, 2009 | 08:05 AM
  #51
SVLRx's Avatar
what kinda wheels do you have. B/c I've been wanting to buy it, but at the same time, my G is my only means of transportation at the moment, so if I were to get a flat on my 20's, I usually use my stock 18 inch wheels as a spare till I can get to the tire shop. And I hear they don't clear the stock 18's
Old Oct 29, 2009 | 08:35 AM
  #52
InTgr8r's Avatar
Same with me... I'm running 20s, but those are 18" stock 350Z anniversary ed. wheels.
Old Oct 29, 2009 | 08:37 AM
  #53
InTgr8r's Avatar
I'll let you know if they get any worse after they've been on for a while.
It would have been damn tight trying to fit the shims in there,
there wasn't much extra space.
IDK if the HPS are any thicker than OE or not.
Old Oct 29, 2009 | 08:45 AM
  #54
soundmike's Avatar
Ian, if you can still measure the HPS, i can do the same with my un-installed OEM's. I'm still contemplating on whether or not to use the stock pads. The allure of being able to switch pad compounds (from street to all-out race) without having to resurface the rotors has me contemplating going the Carbotech route.
Old Oct 29, 2009 | 09:03 AM
  #55
InTgr8r's Avatar
Hey.. no problem.
I'll pull one out tonight & check with the Verniers.
...gotta love top load calipers
Old Oct 29, 2009 | 02:34 PM
  #56
JSpec350GT's Avatar
Nice!
Do you feel any weight of this BBK being added to the car when you drive compare with stockers?
T
Old Oct 29, 2009 | 02:47 PM
  #57
InTgr8r's Avatar
^I expected to, but not really
Old Oct 29, 2009 | 08:13 PM
  #58
soundmike's Avatar
Originally Posted by InTgr8r
Hey.. no problem.
Stop rubbing it in willya?
Front pad material shows as 10.45mm. I don't have the rear pads yet.
Old Oct 30, 2009 | 04:48 AM
  #59
Cabad85's Avatar
Lookin good , can't wait to install mine. I'm not sure if you mentioned this, but did you ever find a new spare wheel that cleared the akebono's?
Old Oct 30, 2009 | 08:44 AM
  #60
InTgr8r's Avatar
not yet...
I did try my 10" rear up front though (for the double switch)
& it's def a no go.
width is OK but the face is too shallow to clear the caliper.
