Hardware for new wheels (nuts, rinngs)
Old Nov 7, 2009 | 03:29 PM
remo's Avatar
If I'm getting new wheels(19") for my 09 X sedan, do I need new nuts or OEM nuts can be used. Wheels are Enkei.
Old Nov 7, 2009 | 03:41 PM
jran76's Avatar
You will need new lug nuts. The Infiniti lug nuts are too big for most aftermarket wheels. Any decent tuner style lug nuts should work.
The Infiniti center bore is 66.1 mm, so you will also need hub rings. The Enkei wheels are likely a 73.1 mm center bore, so you will need a 73.1mm-->66.1mm hub ring.
Old Nov 15, 2009 | 12:36 AM
AlterZgo's Avatar
I would say it depends on the rim. Enkei is a major OEM rim manufacturer so the aftermarket rims they make, depending on the style, may be compatible w/ your stock lug nuts.
FWIW, the Infiniti M45 sport rims are Enkei rims.
netcbc
Wheels & Tires CDN
Aug 25, 2015 09:42 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
RAVSPEC
Wheels & Tires-Vendor
Jul 16, 2015 01:58 AM
si_driver
Jul 14, 2015 12:29 PM
