Akebono brakes fit 2007 G35S Sedan
Old 12-08-2009, 10:18 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
here they are....
Old 12-08-2009, 10:42 PM
E-Ticket Ride's Avatar
Nice work, but a dime width if clearance would make
me nervous
Old 12-08-2009, 10:44 PM
B L U E S L A T E's Avatar
Honda Accord
A dime width is actually pretty good. Great job.
Old 12-11-2009, 08:17 AM
InTgr8r's Avatar
^+1.
This will be a good option for some guys.
Old 12-11-2009, 10:48 AM
sunny G-35 NYC's Avatar
Thank you very much for the pics. I'm going to order my BBK real soon now that I've seen that they would fit under stock wheels. And can you please tell me how big the Front rotors are. Thanks
Old 12-11-2009, 10:59 AM
InTgr8r's Avatar
^the front is 14"
Old 12-11-2009, 12:47 PM
soundmike's Avatar
With at least 15mm spacers. Just in case you missed that part.
Old 12-11-2009, 02:21 PM
InTgr8r's Avatar
^good reminder.
OP edited <bold>
Old 12-18-2009, 12:27 PM
Roadtrip's Avatar
Did you put 15mm wheeel spacers on to clear brake calipers or did you already have 15mm wheel spacers on for appearance reasons?
I ask because I use a set of 350Z rims and winter tires for winter on my 2008 G35S and they have about 20mm less offset (20mm more outboard). It looks nice this way. I have stock wheels like yours. I wonder if I could achieve similar appearance/fit with my stock wheels + 20mm wheels spacers. Maybe 20 is a bit much and and 15mm is better fit?
Any info appreciated. or if someone can point me to thread where this has already been discussed, that would be great. I searched but have not found one addressing stock 07 08 MY wheels with spacers.
Thanks.
Old 12-18-2009, 01:11 PM
Mainer's Avatar
07 G35S Sedan! The clearance issues where with the spokes and the caliper, and not the (stock) rim itself. I used 15mm spacers and it looks great. The stance looks excellent and the rotor and caliper take up a lot of space. I bought the spacers from everthingg35. I dont think the extra 5mm makes a difference it iks less than a half and inch. Check out my previous threads.
Old 01-22-2010, 05:40 PM
G35s-Q8's Avatar
Did you use 15mm spacer for front rims only? or for front and rear rims?
And btw where can i get a list for all the needed parts? i live outside the US and it'll cost me a lot if i ordered it from there, so i'll just need a list and i'll go shopping at the local infiniti dealer .
Old 01-22-2010, 06:49 PM
soundmike's Avatar
http://gshack.org/?p=56
Old 01-22-2010, 06:53 PM
soundmike's Avatar
Forgot to mention, if you're not getting aftermarket SS brake lines, you'll need the shorter banjo bolts and a set of copper washers. (Thanks to InTgr8r for the tip!)
Old 01-23-2010, 05:28 AM
G35s-Q8's Avatar
I'm getting SS lines of course, but should i get G37 coupe lines or G35 lines?
Or it doesn't matter?
  #30
Old 01-23-2010, 06:12 AM
G35s-Q8's Avatar
I copied them here:
Part Number Description
41001-JL00A Caliper Assembly - Front (Right, includes seals and pistons)
41011-JL00A Caliper Assembly - Front (Left, includes seals and pistons)
40206-JL00A Front Disc Brake Rotors (Requires 2)
D1060-JL00A Front Disc Brake Pads
D1080-JL00A Front Disc Brake Hardware Kit
41217-JL00A Front Disc Brake Pins (Requires 4)
44001-JL00A Caliper Assembly - Rear (Right, includes seals and pistons)
44011-JL00A Caliper Assembly - Rear (Left, includes seals and pistons)
43206-JL00A Rear Disc Brake Rotors (Requires 2)
D4060-JL00A Rear Disc Brake Pads
D4080-JL00A Rear Disc Brake Hardware Kit
44217-JL00A Rear Disc Brake Pins (Requires 4)
41218-JL00A Clips (Requires 4)
What i really want to know is, if i went to the dealer and bought calipers + rotors + pads, can i install them? or do i need all of the above
Quick Reply: Akebono brakes fit 2007 G35S Sedan
