for the X, would you run 19x8 all around or?
Old Dec 12, 2009 | 09:20 AM
BlueFlash's Avatar
19x8 up front and 19x8.5 in the rear
both setups will have the 245/40/19
sorry i can't run 19x8.5 up front because don't have the extra 2 wheels in that size.
what do you think?
will the x8.5 in the back have a little more concavity for that staggered look, or will the different sidewalls look funky?
Old Dec 12, 2009 | 01:22 PM
AesonVirus's Avatar
I'd worry first about the outside diameter. All four corners have to match to avoid AWD issues down the road.
Otherwise, I don't see there being enough of a difference front to rear that most would likely not even notice.
Old Dec 12, 2009 | 02:45 PM
nghiars's Avatar
Just run the 18x8s all around so you can rotate the wheels without having to dismount them off the 8.5 in wide rim.
Old Dec 12, 2009 | 06:35 PM
johnnyzee's Avatar
i run 19 x 8 all around with 245 40 19. looks great. rotatable. the 8.5 will stretch the tire in the rear (ewwww).
Old Dec 12, 2009 | 06:39 PM
soundmike's Avatar
The difference in wheel width will have a slight effect on the overall diameter of the tire, even if the tire used on all four corners are of the same size. It shouldn't be much, but i don't know what the threshold is for size differences between front and back on the X.
As for concavity, that would depend on offset and wheel design.
Old Dec 12, 2009 | 06:42 PM
soundmike's Avatar
Not really, at least mine didn't. The tire sidewall is flush with the lip on the rim, if anything.
Here's a pic, it's not very clear but you can see what i'm referring to.
245/40/19 on 19x8.5
Old Dec 12, 2009 | 11:47 PM
BlueFlash's Avatar
245/40/19 on 19x8.5
is this an X or non-X?
Old Dec 13, 2009 | 07:40 AM
soundmike's Avatar
Non-X, the photo was just to illustrate the tire & wheel width comment.
Old Dec 13, 2009 | 08:27 AM
GEE35FX's Avatar
+1, the 8.5" rim is perfect for a 245 tire, it definitely is not stretched.
I would run the same size front and back on the X, enables you to rotate tires front to back, plus you are ensured the diameters are exactly the same for your awd system.
Old Dec 13, 2009 | 11:18 AM
BlueFlash's Avatar
alright then i'm sticking to 19x8...
thanx fellas
Old Dec 13, 2009 | 08:46 PM
RBull's Avatar
Rated M
+1 the 245's on my 8" coupe rims were stretched wearing too much in the centre. 8.5" is perfect.
Old Dec 14, 2009 | 07:28 AM
johnnyzee's Avatar
245/40/19 on 19x8.5
my apologies on the misunderstanding...
what i meant was if the OP goes wider rim in the rear with the same size tire on front and back, the tire won't have the same side profile and have a more "stretched" (for lack of better term) look than the front...which of course, would still be ewww.
Basically, if you're going same size tires all around, wouldn't all of you agree that the same size rims should be used, especially if you have the option such as the OP and myself had when buying?
Old Dec 14, 2009 | 08:08 AM
GEE35FX's Avatar
Exactly Johnny, I think that is what most of the people here said.
Old Dec 14, 2009 | 03:59 PM
johnnyzee's Avatar
^Perfect Wayne, I'm happy we cleared that up...hahahah!
A buddy of mine did that on his audi a4 (awd)... same size tires but wider rims in the rear...it didn't work at all (looks wise), just trying to save someone else the regret of doing what he did.
Old Dec 14, 2009 | 04:11 PM
iiiiiekoiiiii's Avatar
It will not throw the AWD off... Been there Ran that size...
on my X ran Coupe 19s come with 245 on 8.5 and 225 on 8 front...It threw the awd OFF
Changed the Front to 245 ran it for months, and aggressive... No problems at all...
as theyve mentioned 245 on 8.5 is perfect no stretch
245 is a stretch on 10.5 =]
