for the X, would you run 19x8 all around or?
Old Dec 14, 2009 | 08:15 PM
RBull's Avatar
Rated M
Originally Posted by johnnyzee
my apologies on the misunderstanding...
what i meant was if the OP goes wider rim in the rear with the same size tire on front and back, the tire won't have the same side profile and have a more "stretched" (for lack of better term) look than the front...which of course, would still be ewww.
Basically, if you're going same size tires all around, wouldn't all of you agree that the same size rims should be used, especially if you have the option such as the OP and myself had when buying?
Yep, you're good with same size all around. It's the way to go.
Old Dec 17, 2009 | 11:36 PM
tpc303's Avatar
I asked the service manager at my Infiniti dealership if I could run a staggered set up on my X, he said no problem and that the G37x comes from the factory running staggered.
Old Dec 17, 2009 | 11:43 PM
GEE35FX's Avatar
since when??? show me What's he smoking??
Old Dec 18, 2009 | 07:44 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
^+1
Find another dealer. That guy doesn't know his azz from a hole in the ground.
OE spec is;
Double 5-spoke, 17 x 7.5-inch aluminum-alloy with 225/55R17 V-rated all-season performance tires
or optional
Split 5-spoke 18 x 7.5-inch aluminum-alloy wheels with 225/50R18 V-rated all-season performance tires (front/rear)
Old Dec 19, 2009 | 02:58 PM
iiiiiekoiiiii's Avatar
Dealers dont know shyt literally dumb *** a rock...
Im runnin 19x8.5 19x9.5 +35 offset all around, he asked me, if I was using spacers, i said no 35 offset all around they're all the same so it doesnt effect my awd. He was like OKAY good, cause u shouldnt run staggered on the Awd. LOL. me and my boy were laughin, but i was tryina keep a straight face lol.
Old Dec 19, 2009 | 03:17 PM
BlueFlash's Avatar
you could run staggered on AWD, bmw do it, but you have to stay between 0.2-0.7% difference in tire circumference.
http://www.miata.net/garage/tirecalc.html
Old Dec 19, 2009 | 07:16 PM
FlyingLumpia's Avatar
Funny I am running 19x9 +32 with a 15mm spacer and a 19x10 +32 with a 225/40 and 255/35 no problems, on mine. I even got a flat on the way to cali and ran my 17x7.5 +45 with a 225/50 and still no problems.
Old Dec 19, 2009 | 07:35 PM
soundmike's Avatar
They're all still within the same overall diameter, so you're good.
Thebaws11
Jul 2, 2021 11:36 AM
Thebaws11
Nov 30, 2016 12:54 PM
Vqalexisz
Oct 14, 2015 12:48 AM
n2fooz
Sep 4, 2015 07:46 PM
